Just had offset control arm bushings installed....
  • arsevader
    • May 2005
    • 1025
    Originally posted by nando
    Originally posted by arsevader
    Originally posted by erik325i
    Originally posted by ed94r
    Front toe out sharpens corner turn-in response at the expense of tire wear and straight line speed.
    0 front toe aids in straight line speed/tire wear at the expense of turn-in sharpness.
    Front toe-in just sucks.
    Ed
    So, why would factory spec be a few mm toe-in, as Alex stated?
    Straight line stability at speed.
    James
    and lower tire wear, but if you have a couple degrees of negative camber/you drive your car hard your tire wear is going to be screwed anyway.. may as well have responsive handling. ;)
    Toe-in isn't going to lower your tire wear though. You're going to be scrubbing the outside of your tires ever so slightly. 0 toe will give you the least tire wear. I guess complaining about tire wear is for pussies. ;)
    James
    James
    • Digitalwave
      is a poseur
      • 6293
      Re: Just had offset control arm bushings installed....
      Originally posted by etajohn
      I had this done at a well recommended shop and they say it doesn't alter the alighnment. But just looking at it makes me think it has to add toe in and I need it checked. I questioned them on this and they say they do it all the time with no problems. So what gives?
      Thanks.
      Offset bushings just alter caster, they do nothing for toe.
      James
      As others said, completely wrong.
      I have always ran 1/16 toe in front and rear. I only find toe-out helpful for autocross situations.
      I'll take peoples word for it but I still fail to see how offset bushings are going to alter toe. The bushing pushes the bottom of the strut forward thereby increasing caster. Unless you change the length of your tie rods, how does your toe change?
      Just want to know.
      James
      Think about how the bushing causes the whole control arm to move "forward". Without altering the tie rods, this effectively makes them shorter, causing toe-in. And yes, it wears tires a lot faster. Ask me how I know.
      RISING EDGE
