Poly Subframe Bushings
  • cheades
    • 632
    I am just posting to see about those who installed poly rear subframe bushings. Did you use grease when installing them so they wouldn't make noise?
    • 34844
    no need for grease, they don't really move around. my trailing arm bushings came with sillicone grease though, I used that and have never had squeaking.
    • Digitalwave
      is a poseur
      • 6299
      No grease, no noise.
      RISING EDGE
      • rwh11385
        lance_entities
        • 18403
        Fucking liar. No need for grease....actually used some epoxy.....but that's not the case.
        They are loud and you get the differential whine like a mother.
        If you want poly bushings and street the car, IE street.
        • Digitalwave
          is a poseur
          • 6299
          I didn't get any more diff whine with mine, and really didn't notice any more noise.
          RISING EDGE
          • rwh11385
            lance_entities
            • 18403
            Maybe my M coupe diff bushings helps increase it too. But the whine to start was loud. I got used to it though.
            • Digitalwave
              is a poseur
              • 6299
              I am sure the diff bushing does add to it. I only have poly subframe bushings and stock TA bushings though. That might make a slight difference as well. What fluid are you running in your diff? I bet some Redline 75w90 with LSD additive would make a big difference.
              RISING EDGE
              • rwh11385
                lance_entities
                • 18403
                yeah, redline in both tranny and diff.
                  • 34844
                  I have a poly diff bushing (along with every other bushing), my diff is totally silent. something is wrong with yours...
                  • rwh11385
                    lance_entities
                    • 18403
                    what brand? Skafrog said it was nothing new and said people had returned RTRS bushings because of the noise.
                    There is a weird shifting noise when I get on/off the gas that has me curious. Might be the mount bushing. Ask Sean or Trevor about what it was like.
                    • Digitalwave
                      is a poseur
                      • 6299
                      I have that same noise. Always have, even when it was auto.
                      RISING EDGE
                      • rwh11385
                        lance_entities
                        • 18403
                        okay. well, i had it too, but the bushings and likely the m coupe made it much louder. Sean said something like it was normal and said why, but I forget.
                        anyway. if you care about a quiet ride....dont install race suspension pieces. bottom line. :P
                          • 34844
                          what brand?
                          I got the diff bushing from bmwbushings.com, everything else is IE.
                          I have a clunk noise in the rear but I'm pretty sure it's because there are only 3 bolts holding my diff on.. :?
