tips for control are removal.??
  • call me jack
    • Jul 2010
    • 425
    i'm trying to remove the control arms, to replace the ball joints in an '87 325ic. i am having a hard time getting to the bolt that attaches the arm to the sub frame. any tips?
  • StereoInstaller1
    GAS
    • 22679
    Beat a 22mm wrench with a hammer until it has a good bend in it.
    I prefer the 8lb sledge with the wrench on a curb, but when you hit that motherfucker, it will fly.
    Closing SOON!
    Thanks for 10 years of fun!
    • BrettsE30
      • Feb 2011
      • 306
      On my vert I used a regular snap on wrench in I belive a 22mm as stated above. I just had to turn it like 2 nothes at a time. It took forever but it will work.
      I need your obd1 parts! Harness intake ecu etc.
      E30 Your Daily Money Pit
      • AndrewBird
        The Mad Scientist
        • 11892
        Impact wrench or a large breaker bar. And I don't mean a pipe on the end of a ratchet.
        • StereoInstaller1
          GAS
          • 22679
          My "taco wrench" gets damn near 1/4 turn. Lots of guys just cut a wrench shorter, but the taco wrench kicks ass on all of that.
          Closing SOON!
          • Kershaw
            • 11822
            why is there a problem getting to this? are the cabrios different?
            be very careful if you're just replacing the ball joint. they will pop the fuck out with a vengeance halfway through....
            AWD > RWD
            • 30THIRTY
              • 339
              I cut the boxed end off of a wrench so I could fit breaker on it
              • DRTSRFR
                • May 2008
                • 1836
                I get to mine from the top with extensions and a swivel...both off in less than 15 minutes.
                Suspension tips here...
                http://www.r3vlimited.com/board/album.php?albumid=757
                • devon.818
                  • Feb 2011
                  • 2937
                  Swivel from the top and breaker bar!
                  As for the rest of control arm compress the ball joint with a jack, hit it with a hammer HARD a few time. Take jack off and it should slid out. Same goes for outer!
                  Don't use wd40 on bushings it will eat away at rubber, silicon spray is better and won't degrade bushings
                  • lbreevesii
                    • Aug 2009
                    • 412
                    I managed to get mine off with just a large adjustable wrench. It wasn't easy, but I didn't have a 22mm wrench handy.
                    I don't always wreck cars, but when I do I wreck them into trees.
                    91' 318is S50 swap - The Black Widow
                    • seatown88
                      • 331
                      I had pretty good luck with a crescent wrench also, tedious though. Lots of little turns
                      • willworkfore30s
                        • Aug 2011
                        • 1090
                        I did it with a huge crescent cause it was all that I had. As others said, it took forever and was a huge pain in the ass.
