brake wear sensors inboard or outboard?
  • pig4bill
    • Sep 2004
    • 122
    Does it matter if the brake wear sensors go on the outboard or inboard pad? The front pads are identical so it can go on either. I can't remember if they can only go on one or the other rear pads.
    And my friggin warning light is still on. Does this mean I have a break somewhere or a short somewhere?
  • Digitalwave
    is a poseur
    • 6299
    You probably have a fray at least if not a break somewhere along the wires. The sensors go on the inboard pads.
    RISING EDGE
    • pig4bill
      • Sep 2004
      • 122
      A fray would cause a short, not the same thing as a break.
      • Digitalwave
        is a poseur
        • 6299
        Yeah, but either of them could cause the light to come on.
        RISING EDGE
        • Globulator
          • Sep 2005
          • 1
          Re: brake wear sensors inboard or outboard?
          Maybe... if you pull the instrument cluster and put it to one side, test pin 26 on the blue car-side connector and pin 21 on the white car-side connector with an ohm-meter. You should get about 2 ohms if your wiring and sensors are fine - verify this by disconnecting a sensor. Test one of the pins to earth also - it should not be touching (100k or above). You can use the spare leads of a small resistor to measure the plugs without damaging them.
          If you have a circuit the problem is in your cluster. If not - it might be any day now. Carefully take it apart and look at the solder joints. Keep earthing yourself to avoid static. On the RHS above the temperature gauge the resistor normally works it's way unsoldered. Resolder all similar connections on the board carefully - or at least all suspect and/or easy ones.
          While you are at it heck the 68ohm resistor that gets hot is still a 68ohm resistor and replace any bulbs you think look a bit old.
          When reassembled the light should now stay out unless you crank the engine - at which point it should flicker slightly.
          1986 E30 325i Convertible
