control arm clunk still after replaced
  • dnick
    • Apr 2011
    • 1377
    Originally posted by 87e30
    Just imagine all the vibration... ugh.
    hahahah
    • devon.818
      • Feb 2011
      • 2937
      so just go with the 75D poly ones i guess
      • AndrewBird
        The Mad Scientist
        • 11896
        Is this guy for real?
        • Sagaris
          • Sep 2009
          • 2243
          I had solid aluminum engine mounts on a FWD car. The original mounts were failing far too frequently so I figured the Aluminum mounts would be the solution. Well, it never broke but the car sure was annoying to drive after that. The B-pillar resonated and buzzed past 5000 rpm and you could feel vibrations everywhere. I will never do that again.
          • ill4noreason
            • 2710
            Like I said 3 days ago before you even posted this buy oem be happy they have lasted 22 years I think you will be ok for a while lol.
            My Multi car part out. Need a part? Pm me...
            http://www.r3vlimited.com/board/showthread.php?t=193051
            Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
            http://www.r3vlimited.com/board/showthread.php?t=215044
            Have you done business with me? If so leave me feedback here...
            http://www.r3vlimited.com/board/showthread.php?t=188307
            • devon.818
              • Feb 2011
              • 2937
              just read something about having the suspension preloaded when you torque down the control arm bolts and what not, is this true?
              if so that might be my mistake...
              • mr.vang
                • 4371
                a bad control arm one clunk when turning over a bump. a loose shock clunk when you goes over bump no matter if your turning or not.
                • SedanSandwich
                  • Feb 2011
                  • 314
                  when you pressed in the bushings you lined up the marks on the lollipop and bushing right? how long did you wait after you attached the lollipop and let the car rest on the ground? if you wait too long the bushing will not set properly and might be your problem. unlikely but you never know.
