Changing Front Hubs
  • kencopperwheat
    King of Kegstands
    • 14396
    Changing Front Hubs
    Every time I go auto-x, the tech guy tells me that I should probably change my front left wheel bearings. According to him the passenger side one is fine. I'm just going to buy a new hub instead of dealing with pulling the bearing and what not. Do I have to do both at the same time, or can I just do the one that needs replacing? How long of a job is this for one side?
    Originally posted by Gruelius
    • 34835
    shouldn't be a problem, but that right side probably isn't far behind. if you are paying for the work to be done I'd just have them do both if you can.
    • arsevader
      • May 2005
      • 1025
      Re: Changing Front Hubs
      As if you have a choice. That's how they come as one unit, hub,bearing and ABS toothed gear.
      Just do the one that needs it. It's not the type of job where doing 2 saves you any time or money.
      I'd say, if you've never done it before and it goes smoothly, about 2 hrs form start to finish. You could do it in an hour if you're fast.
      Get a new dust sheild, grease cap and hub nut. The nut is 36mm. A regular 36mm socket will fit, you may have trouble with the thickness of a deep socket and it's not needed.
      James
