Rear subframe overhaul. Give me suggestions.
  • ryan_george
    • Mar 2004
    • 331
    Well it seems like most of my bushings are pretty worn.
    I'm looking to replace subframe, trailing arm, and diff bushings.
    This is what I'm thinking so far:
    IE green urethane subframe
    IE urethane trailing
    Diff..... ?? no ideas yet
    Luckily I've got a spare subframe and arms, so the install should be relatively painless.
    Any more options/suggestions?
    -Ryan
  • Digitalwave
    is a poseur
    • 6299
    Don't worry about the diff bushing, they last forever.
    RISING EDGE
      • 34847
      I agree, as long as it's in good shape. Mine was like new, so I wasted a bunch of effort and money replacing mine with urethane, and I don't think it made a lick of difference.
      • AdamF 88iS
        • 2051
        Urethane is going to move around on you, especially in the trailing arm bushings.
        I would use stock bushings for the arms, and get some resin/filler to fill the gaps in some fresh stock subframe bushings and shove those in.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • Kilomph
          • Oct 2004
          • 599
          Since you'll have the diff out, you might as well upgrade to an M Coupe diff bushing.
          • Beej '86 325es
            • 2639
            If you're pulling the subframe, and have a lowered car, you might invest in IE's weld on camber kit. I have this and their adjustable toe kit and I'm pretty happy with it. It will allow you to get rid of more negative camber than the adjustable trailing arm bushings will...and it'll do it the right way.
            -Brandon
            '86 325es S50
            '12 VW GTI Autobahn DSG
            '03 540i M-Sport (sold)
            '08 Jeep SRT-8 (sold)
            For sale:
            S50 TMS chip for Schricks
            • Bimmerfanatik
              • May 2004
              • 5349
              So you'd recommend usign stock bushings over the urethane? I've never heard of the resin/fill method...
              • m42technic
                • 1056
                If I had to do it over, I wouldnt have gone for urethane RTAB's.
                James Peacock
                WWFSMD?
                • rwh11385
                  lance_entities
                  • 18403
                  if I had to do it again, I wouldn't. I'd sell my car and get one that had never seen snow or salt.
                  • Beej '86 325es
                    • 2639
                    True words.
                    -Brandon
                    '86 325es S50
                    For sale:
                    • Nick325is
                      • 1409
                      Tell me more about the IE rear camber and toe kits. I have been looking at them and trying to decide if I want them. How easy are they to use once installed?
                      Nick
                      • Beej '86 325es
                        • 2639
                        Nick
                        Check this site out, he's got some good pictures and details on it.
                        Once it's in there, it's difficult to get a wrench in there to adjust, I actually haven't tried...because really, once you get it where you want it, why change it?
                        -Brandon
                        '86 325es S50
                        For sale:
                        • Nick325is
                          • 1409
                          I'm not seeing a link in your post. I was referring to less negative camber on the street and then more for the track etc.
                          Nick
                          • Beej '86 325es
                            • 2639
                            Nick
                            ...wooops. I probably got distracted working in autocad and tried pasting that in there instead.
                            http://www.e30m3performance.com/inst..._sub/index.htm
                            Really, if you've got your car slammed pretty low, like with a G-C kit, I'd probably just leave it alone. Adjusted all the way, I can only dial out my camber to about -2.5 degrees, which is a lot better than it was, but it's hardly worth changing for the track.
                            -Brandon
                            '86 325es S50
                            For sale:
