I installed some axxis ultiamtes pads, new rotors, stainless steel lines, and a 25mm MC i cant activate abs, or at least cant feel it. the pads are fairly new and after a few lighter stops i tried a couple hard ones
cant activate abs with new brake stuff
Tags: None
did you remember to reattach yoru ABS sensors? I dont know what would happen if you left them out, maybe the abs light coming on, or abs actually coming on, but you could have blwon the fusable link in the relay too i guess? just a coincidence.
Kyle1988 M3, 97 840, 99 XJ
DILLIGAF -
i should have jsut said i couldnt lock the wheels up. What i meant was the car doesnt seem to brake hard enough to be able to activate it. Unless it doenst feel like its pumping the pedal like in other cars, which i really doubtComment
yeah, the pedal is quite stiff, although i think i bled the left front instead of the right first
i dont ever remember locking up a wheel before these up grades, but i never really had to stop that fast. the tires are 3 toyo fz-4's with one spare btwLast edited by nickmp0wer; 09-27-2005, 09:57 PM.Comment
jk.... well... maybe that would help, but
does the anti-lock indicator lamp work? it should turn on while the system checks itself on startup.... if no lamp, them the bulb is out, and the ABS may not work.... otherwise it should work properly. let the new pads break in.
as long as you get all the air out of the system it doesn't matter what wheel you start at... i always go around the car at least twice to make sureComment
i just thought, did you remember to put the cap back on your brake fluid resivoir? Sometimes we overlook the simple stuff....
DILLIGAFComment
Re-bleed your brakes in this order: RR, LR, RF, LF.Originally posted by nickmp0weryeah, the pedal is quite stiff, although i think i bled the left front instead of the right first
i dont ever remember locking up a wheel before these up grades, but i never really had to stop that fast. the tires are 3 toyo fz-4's with one spare btw'91 318is
sigpicComment
well how many times should i have clear fluid commig through? i will check for leaks in the stainless lines too. though it seems like the pedal isnt going any where near the floor. anyone one else have the 25mm MC?Comment
thats basiclly how we did it except my dad would just press the pedal once. and there was nice new blue fluid comming through. do the brake boosters ever fail or weaken?Comment
What do you mean he would just press the pedal once? You need to have him pump the brakes (I usually do 6 pumps or so) and hold the pedal down on the last pump. Then, you open the bleeder screw for a few seconds and close it BEFORE your dad takes pressure of the brake pedal. Repeat this a few times per corner and make sure you do it in the order i told you.Originally posted by nickmp0werthats basiclly how we did it except my dad would just press the pedal once. and there was nice new blue fluid comming through. do the brake boosters ever fail or weaken?'91 318is
sigpicComment
i dont see why pumping it would be nessary. I would open the bleeder then he would press down the pedal then i would close it and he would let offComment
You asked for advice, I told you the RIGHT way to do it. End of story.Originally posted by nickmp0weri dont see why pumping it would be nessary. I would open the bleeder then he would press down the pedal then i would close it and he would let off'91 318is
sigpicComment
