Early 318i brake swap question...
    • 37833
    Not your typical question, more like the opposite of what you would expect.
    If I swap large diameter 325i strut housings on to an 85 318i can I retain the calipers, brackets, and rotors from the original 318i small diameter strut housings? Just want to confirm it will interchange.
    Please don't ask why, I just need an answer!
    Grover Beach, California
    BimmerHeads.com
  • Jaxx_
    • Dec 2009
    • 1880
    yes.
    edit: and you don't even need to retain the 318 wheel bearing or anything. just swap the brake rotor and go
      • 37833
      Originally posted by Jaxx_
      yes.
      Excellent, thanks. I've owned many E30s but never an early 318!
      BimmerHeads.com
      • Jaxx_
        • Dec 2009
        • 1880
        consider yourself lucky. lol
        • Jean
          • 18228
          LOL.... just swap the rotors/calipers over man :)
            • 37833
            Swap successful. 87 325iS strut housings with 85 318i calipers and rotors.
            BimmerHeads.com
            • jeffnhiscars
              • Jun 2011
              • 6011
              Im in need of a DS 45mm strut housing. Any chance you saved it and would part with it ?
              Alice the Time Capsule
                • 37833
                Sorry man, I scrapped them.
                BimmerHeads.com
                • E30RedtopSR
                  • 202
                  Change the master to or you will experience some craptastic braking performance. Early 318's used a tiny master bore.
                    • 37833
                    Why would my braking performance change? I am using the same calipers, pads, and rotors.
                    BimmerHeads.com
                    • E30RedtopSR
                      • 202
                      Ahhhh sorry fella, forgive sir. My attention to detail is apparently lacking, lol.
                      Brian
