Big brake kit - upgrade with bigger engine?
  • 3rotore30
    • 34
    Hi,
    I currently own a 1991 E30 318i with ATE front and rear calipers with the larger front 260 x 22mm vented from disc rotors.
    I will be upgrading the engine soon (300kg!) and was thinking about doing the brakes while I was at it to the Massive 4 piston Wilwood caliper on the larger 280mm disc rotor.
    I have no intention in doing any track work with this car but just a bit unsure on how the standard brakes will perform with the extra weight up the front. I am not fussed about filling in wheel gaps either as I will be running either a 15 or 16' wheel.
    I am more inclined to rebuild the standard calipers, upgrade to braided lines, better pads and a pair of DBA slotted rotors up the front (already bought rear ones).
    What would you suggest?
  • TurboJake
    • 3780
    What are you putting in there that's 300kg more than the M42? A turbo diesel?
    The stock brakes are pretty actually pretty good. I can understand if you're putting in a V8 or V10, definitely. But the stock brakes stop an M30 swapped car just fine.
    Depending on what you're putting in (Which we don't know), I would be inclined to say the stock calipers, braided lines, pads, and slotted rotors would be more than enough.
    Leave Me Transaction Feedback
    • E30RedtopSR
      • 202
      Judging by his user name he probably meant KW. 20b?
      Just a guess. He is from AU
      Get bigger brakes. I have a 400hp Sr20det in my E30 and the stock stuff even with good pads can be spooky.
      Size the calipers pistons and master cylinder accordingly though.
      • 3rotore30
        • 34
        No, I meant weight of the engine, 300kg ~ 660lbs. Never mention 300kg MORE...
        E30RedtopSR, was your e30 running the smaller thickness rotors? IIRC one set is 11mm and is solid while the other is 22mm thick and vented.
        • burkey001
          • Feb 2011
          • 608
          Holy hell.
          Get the 300x32 kits front and rear radial mount kits and don't look back.
          I can run 30 minute sessions without fade on these.
          88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
          90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
          • 3rotore30
            • 34
            it's not for track work...
            • burkey001
              • Feb 2011
              • 608
              Doesnt matter sir. A triple rotor is a triple rotor.. you will need a means to stop safely on the street.
              • 3rotore30
                • 34
                I'll wait for more advice.
                • Massimo
                  • Jan 2008
                  • 3207
                  Hehe there is a guy down here in SA who has a 13b and that shit is insane. this will be godly.
                  I would just get in contact with Massive he know his shit and will point you in the right direction. Though I remember seeing a comment once where Lee said anything over 400hp and you should be looking into 330mm disc but don't quote me on that.
                  • 3rotore30
                    • 34
                    standard front brakes on a cosmo were only a single piston front caliper on a 272mm rotor with a car that weighs 1500kgs... so I am more leaning towards his 280mm 4 piston combo.
                    • burkey001
                      • Feb 2011
                      • 608
                      You can drive a car with your feet if you want to, doesn't mean its a good idea.
                      Maybe its just me but I like stopping and knowing I can stop. For the sake the extra $400 versus the money pit a 20B swap will be, I'd not even think twice about it.
                      0.02
                      • Massimo
                        • Jan 2008
                        • 3207
                        Yeh that is what I would have guessed as well. Are you going to bump the power up on the stock 20b? If you do what power do you expect to see?
                        • 3rotore30
                          • 34
                          0.02
                          yes i know where you're coming from but with the bigger brakes then i will have to change the wheels. i didn't want to go above a 15' rim and I know the biggest of the brake kits wont fit under the wheel. not something that I really wanted to do to be honest.
                          Massimo, just standard for a while. the motor has low compression but still runs okay. will require a rebuild in the not to distant future (minimum 2k). I just wanted to get it in the car asap so I can get a mod plate before they change the rules in Queensland to follow the new ones that NSW have.
                          Funny that it's legal to have a 20b turbo in this car in Queensland but illegal in NSW under the new rules...
                          • Massimo
                            • Jan 2008
                            • 3207
                            Yeh the rules are rediculas and out of hand. I don't know where to go with my car, if I want to do what I like then it will have to become a track car, but I still want to be able to drive her on the road.
                            It sucks allot.
                            • E30RedtopSR
                              • 202
                              22mm vented. That stuff is gone now, Putting together a bbk of my own design.
                              4 piston Mitsubishi calipers
                              304mm rotors from a euro MG-TF
                              25mm master from a 750il.
                              Rear is secret combo to be revealed at a later date when details are worked out.
