Opinions on this RSB 'fix'?
  • Den
    • Mar 2004
    • 162
    http://cgi.ebay.com/ebaymotors/EASY-...QQcmdZViewItem
    Looks pretty easy to replicate.
    Anyone got a bushing available to measure?
    • 34839
    that looks extremely cheesy.
    • permit
      • Mar 2005
      • 3363
      I want to see someone build a car completely out of ebay parts.
      • erik325i
        • Jan 2005
        • 3567
        That's being done. Look up posts from the username "budget beater"
        • Den
          • Mar 2004
          • 162
          Gee, that was productive.
          Let's try again.
          Does anyone think this would work?
          I've seen references to filling the bushing gaps with 'resin,' presumably while in liquid form. How about solid PVC?
          • RobertK
            Kicked cancer's ASS.
            • Jun 2005
            • 5864
            Same here.. ;)
            • Digitalwave
              is a poseur
              • 6299
              Let's try again.
              Or you could not be ghetto and you could buy urethane or delrin bushings...
              RISING EDGE
              • Den
                • Mar 2004
                • 162
                If this fix works, I don't care how ghetto it is.
                Buying fancy new bushings is not the problem; removing the old bushings is.
                I'll buy any bushings you suggest if you'll remove my old bushings.
                If you could manage to get vaporized rubber all over my car, that'd be great too.
                Torching the subframe bushings certainly was fun, except I did it too close to my car and got "negro" ghosts all over my car from the burning rubber.
                Originally posted by Jordan
                Dude that shit got EVERYWHERE. Never again.
                • Dave
                  E30 RAT
                  • 11675
                  http://www.r3vlimited.com/board/show...t=49944&page=2
                  Buy them, do a write up and let us know how they go.
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • Digitalwave
                    is a poseur
                    • 6299
                    Who gives a shit about the mess it makes? Do it away from your car and there won't be a problem. It was easy to do, and only took about 3 hours total.
                    RISING EDGE
                    • Den
                      • Mar 2004
                      • 162
                      The rear subframe job is pretty much universally considered to be a pain in the ass.
                      Doing it "away from the car" is only possible if you first remove the subframe, to which the trailing arms and differential are attached. I have better ways to spend my time than wrestling with the 90-lb diff in my gravel driveway so that I can change a couple of bushings. Popping off the bushing cover and sliding in a few shims sounds "easy." What you did does not.
                      • Den
                        • Mar 2004
                        • 162
                        We already have a guinea pig.
                        After I get some measurements, I'll do a Lowe's / Home Depot DIY write up.
                        • Digitalwave
                          is a poseur
                          • 6299
                          Well I guess to some of us a couple hours of a pain in the ass is worth it to do something right.
                          RISING EDGE
                          • Den
                            • Mar 2004
                            • 162
                            There's a joke there somewhere. . .
                            Anyhow, I think a better example of "doing something right" would be replacing the water pump while doing the t-belt because it's there and it saves you labor in the long run. If this bushing fix works, there's nothing any more "wrong" with it than there is with any other suspension mod. If the fix doesn't work or doesn't last long, BFD. I'm going to make my own for ~$2, and the install might take all of 30 minutes.
