Treehouse cabs affect camber?
  • parkerbink
    • Jun 2004
    • 10138
    Below are the stock values. My alignment got everything but the unadjustable camber spot on. My caster is:
    LEFT 2.02
    RIGHT 2.14
    Do the treehouse cabs affect this and is it something to be concerned with?
    Thanks
    STOCK #s:
    Left camber : -1.89
    Left caster : 9.53
    Toe : 0.15
    Right camber: -2.03
    Right caster : 10.22
    Toe : 0.15
    Here is the cab for referance:
  • parkerbink
    • Jun 2004
    • 10138
    No one has any input? Someone must have.
    • Dave
      E30 RAT
      • 11675
      PM Skafrog - he would know.
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • parkerbink
        • Jun 2004
        • 10138
        Good idea! I tried calling them today got vm.
        Thanks Dave!
        • kencopperwheat
          King of Kegstands
          • 14396
          They affect caster only. The negative camber is from your springs.
          Originally posted by Gruelius
          • parkerbink
            • Jun 2004
            • 10138
            M3 springs affect camber? Is it something to be concerned about? Is there anything short of changing the springs I can do?
            Thanks Ken.
            btw no luck with GOOD upholsterers. Still looking though.
            • PeaveyBassist
              • Sep 2004
              • 3511
              Camber plates will allow you to adjust camber back to "stock" specs which will allow for better tire wear. Anything that lowers the car from stock (m3 springs) will give you more negative camber. Get some camber plates :)
              Will
              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
              Welcome e30 (brilliantrot '90 325is) 12/23/06
              DaveCN = Old Man
              My signature picture was taken by ME! Not by anyone else!
              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
              • kencopperwheat
                King of Kegstands
                • 14396
                Thanks Ken.
                The M3 springs will give you a bit of negative camber. I wouldn't be concerned about 2 degrees. It'll give you a little more stability into hard corners.
                Don't worry about the upholster; Diego found me one in Peru for an excellent price.
                • parkerbink
                  • Jun 2004
                  • 10138
                  Thanks guys, Sorry I couldn't help, Ken.
                  • Digitalwave
                    is a poseur
                    • 6299
                    Any spring that is lower than stock will add camber. The lower you go the more camber you get. What you have is not enough to worry about.
                    RISING EDGE
