abs delete? worth it?
  • KenC
    King of Kegstands
    • 14396
    #31
    Originally posted by FunfGan
    Never understood it myself. Brakes worked excellent, just couldn't lock them. I'm assuming it had to do something with grippy tires, and boat anchor wheels.
    Might be the wheels. We ran shaved Star Specs on bottlecaps.
    Originally posted by Gruelius
    • smooth
      • Apr 2005
      • 1940
      #32
      This is copied from Koala Motorsport's E30 M3 Repair Manual and posted on e30tech.
      Anti Lock Braking System Description
      Goals of Anti Lock braking
      Braking stability (freedom from wheel-lock-induced skidding)
      This involves maintaining the car's stability not only as brake pressure is gradually increased up to the wheel lock limit, but also when brake pressure suddenly rises steeply, as in a panic brake application. The ABS system will not prevent skidding if stability is lost for reasons other than wheel lock, such as exceeding the maximum cornering speed.
      Steerability (no break-away from chosen line during avoidance action)
      This means that even during a panic brake application the driver will ordinarily still be able to steer around an obstruction or to apply the brakes while actually cornering, without affecting driving stability or the ability to steer the vehicle.
      Note however, that the system cannot prevent the front or rear end from breaking away during emergency avoidance action because of such factors unrelated to wheel lock such as exceeding the maximum cornering speed.
      Optimum Braking Distances
      It is a well known fact that a rolling wheel can transfer higher frictional forces than a locked (skidding) one so that, all other things being equal, a car equipped with ABS should achieve a shorter braking distance than the same car without ABS would in a locked wheel stop.
      To sum up, the fundamental task of the anti locking system is to prevent accidental wheel locking, thus, help to maintain the vehicles stability and steerability whenever the brakes are applied.
      In order to achieve this objective, the ABS has to operate extremely quickly and accurately. This can only be ensured by recourse to a complex electronic control system. The input signals needed to permit the electronics to regulate operation of the brakes are derived from changes in the speed of wheel rotation and the degree of wheel slip.
      ABS utilizes a four-wheel regulating system, with individual regulation at the front wheels and a "select low" circuit for the rear axle with individual sensors at the rear wheels. The characteristics of the hydraulic dual circuit have not been altered and conform in every respect with non-ABS equipped cars.
      "Select low" refers to the regulating action that is governed by whichever wheel is closer to locking up or skidding. This ensures that the lower available braking force at the wheel is used as a basis for determining brake action to prevent individual rear wheel lock up. The other wheel, therefore, can then accept greater lateral locating forces. This form of regulation was chosen for the rear axle because vehicle stability has to have the highest priority when the system's characteristics are chosen.
      Theory of ABS operation
      Suitable signal sources for use as guide values are road speed, wheel acceleration or deceleration and wheel slip.
      When a vehicle is braked or accelerated, frictional forces must be transmitted between the tires and the road surface. If a brake effort is applied to a rolling wheel , a braking torque is developed whereupon the tire distorts and slip occurs so that the wheel rolls more slowly than the vehicle's road speed would lead one to expect.
      This can be expressed in a mathematical form
      µ = VF - VR x 100 (%)
      VF
      Where:
      VF = Vehicle speed
      VR = Peripheral speed of wheel
      µ = Slip
      ABS Operation
      A pulse generator (sensor or speed detector and gear wheel) provides the necessary information on the tire / road situation, and transmits its signals in proportion to wheel speed to the central electronic control unit. This processes the signals from the wheels and decides whether and to what extent the hydraulic unit should begin to influence the normal braking pressure build up.
      The signals from the speed detector (sensor) are transmitted to the electronic computer. Differentiation of the various speed signals enables wheel deceleration or acceleration to be identified. In addition, various logical criteria are applied to form the reference speeds from the individual speed signals.
      A comparison then takes place between wheel speed and reference speed to obtain the slip signals.
      Continuous comparison between wheel slip, wheel acceleration and deceleration and the threshold values are stored in the electronic memory enables the dynamic condition of each wheel to be monitored.
      If the retardation threshold and/ or the slip threshold are exceeded, pressure regulation commences. The electronic control unit initially transmits the necessary signals to the hydraulic unit to maintain pressure in the brake circuits at the level then reached. After this, if necessary, pressure reduction or pressure increase signals are transmitted.
      The hydraulic unit is supplied with three kinds of instruction signals from the electronic control unit. Pressure retention, pressure reduction, and pressure increase. These regulating phases or regulating cycles are constantly repeated during the regulated brake application until the car comes to a standstill, or until pedal pressure drops below the regulating system's cut-in point.
      Vehicle speed, wheel speed, and wheel deceleration are the governing factors for the regulating cycle during a regulated brake application.
      Driving cars equipped with ABS
      As described in the section ABS Operation, the ABS warning light lights up when the ignition is turned ON and should go out when the engine starts.
      Then the ABS is activated and the BITE program begins to operate. If the ABS warning light goes out, the system is fully operational.
      Once the car exceeds a speed of 7.5 mph (12 km/h), The ABS is capable of regulating brake applications. Below 4 mph (6km/h) the regulating action ceases. The anti locking system does not start to operate again until the car has again begun to move at a speed higher than 7.5 mph (12 km/h).
      Important
      • It remains the responsibility of the driver to suit his driving style and speed to road and climatic conditions and the level of traffic encountered
      • Although the ABS brings benefits in an emergency in terms of stability, steerability and braking efficiency, it is not capable of defying the normal physical laws of motion
      • This means that if the driver enters a corner at a speed beyond the vehicle's cornering limit, or does not maintain the minimum safety margin when driving close behind the vehicle in front, even the ABS will be unable to avoid the risk of an accident
      The sole purpose of the ABS is to assist the driver when braking in an emergency. It increases active safety and helps avoid accidents and collisions.
      The regulating action of the anti locking system takes place in fractions of a second. The driver will notice a pulsating effect through the brake pedal. At low speeds the noise of the hydraulic pump assembly in operation will also be heard.
      These feedback effects from the system to the driver have been deliberately accepted by BMW as a means of confirming that the ABS is in action.
      Electronic control unit
      A multi-channel electronic computer receives the electrical signals for the pulse generators. These signals are proportional to the speed at which the wheels are rotating. From them the computer derives the acceleration, deceleration and slip values. Logic circuits then integrate these values and generate control instructions for the electromagnetic valves in the hydraulic pump assembly.
      Signal processing in the computer determines the regulation action of the system. Complex integrated circuits of the digital type are used to ensure the necessary high level of operating reliability and narrow tolerances.
      The electronic control unit can be divided into three functional zones:
      • signal processing (computing)
      • logic circuits (regulating)
      • safety circuit (test monitoring)
      Signal processing has the task of accepting the wheel speeds as they arrive from the pulse generators and deriving from them the regulating values such as peripheral deceleration or acceleration at the wheel and the slip information in a form suitable for the logic circuits.
      The logic circuits which receive the signals as stated above, generate the actual adjustment instructions such as pressure build up, pressure hold or pressure reduction, which are passed to the solenoid valves on a hydraulic unit.
      Faults (e.g. deriving from the pulse generators) which can arise as a result of normal manufacturing tolerances are filtered out before processing, before they pass to the amplifier stage.
      The safety circuit is used to monitor the system before each use and while in motion, to make sure that it remains operational.
      BITE (Built-In Test Equipment) test cycle
      This test cycle forms an active part of the safety circuit. On the one hand it checks operation of the two regulating modules by a predetermined test program, and on the other hand it transmits a test signal to ascertain that the built in safety circuit is itself in working order.
      The safety circuit and its monitoring devices check the following items :
      • The presence of the general switching signal
      • The signal which switches the return flow pump on and off, or the presence of this signal (return pump monitoring)
      • Control of the valves
      • The valve operating periods (logic monitoring). The maximum valve operating times are monitored here by a combination logic circuit, these maximum times are governed by physical considerations
      • In a 20 second cycle, various items including the pump motor, control sensitivity signals, the test cycle, acceleration, etc.
      • Battery voltage (over- or under-voltages at the electronic control unit)
      If an error is detected, the error memory is activated, the ABS warning light comes on, the ABS is rendered non-operative and any braking which is necessary takes place by conventional means.
      Hydraulic pump assembly
      The hydraulic pump assembly is located inside the engine compartment and either reduces the brake fluid pressure in the wheel brake calipers during the regulating cycle, or keeps it constant as appropriate. The hydraulic pump assembly cannot by itself raise braking pressure, so that as a result the pressure which the brake master cylinder has built up cannot be exceeded. (Please note this is relevant
      only to the systems used on older cars, such as the E30. New systems include pressure pumps to allow individual activation of brakes.)
      The hydraulic unit consists primarily of four 3-way solenoid valves (one for each wheel brake cylinder; the rear brakes count as one), two reservoirs (one for each brake circuit) and the return flow pump. When the brake application starts, the solenoid valves are de-energized and the brake fluid can flow from master cylinder to calipers.
      To built up pressure, the connection between master cylinder and caliper is reopened. Since the master cylinder is still at increased pressure at this stage, the pressure in the caliper also builds up.
      As pressure builds up and the regulating action commences, the valve switches to its central position - the pressure hold phase. This blocks the passage from the brake master cylinder to the calipers, so that effective pressure at the wheel brake cylinders cannot rise any higher.
      In the subsequent pressure reduction phase the valve shifts to its third position. The connection between master cylinder and caliper remains interrupted, and brake fluid is now permitted to escape from the caliper to the reservoir. The return flow pump which starts as soon as the regulating action is initiated delivers this fluid back to the master cylinder.
      Pulse Generators
      Rotating movement of the road wheels is detected by inductive sensors and the resulting electrical signal is transmitted to the electronic control unit.
      For the front axle the signal transmitters are arranged axially and require no adjustment. They are installed in the stub axles, with the gear wheel (which generates the actual impulses) pressed into the front axle hub.
      At the rear axle, the sensors are attached to the wheel hubs between the two wheel bearings and the pulse generating gear wheel is integrated into the spacing sleeve used on the wheel bearings.
      The speed detectors consist primarily of a magnetic core and coil. The pole is surrounded by a magnetic field. As the wheel revolves, the teeth of the gear wheel move through the magnetic field. This varies the magnetic flux and induces a voltage in the coil of the speed detector.
      The frequency of the pulses generated by the successive teeth is proportional to the speed of the rotation of the road wheel.
      Notes on maintenance and repair
      The anti locking brake system is fundamentally maintenance free. It is monitored continuously by the built-in safety circuit and the monitoring circuits. If a fault is detected, the ABS warning light will come on and the ABS itself becomes nonoperational.
      If work is performed on the brake system such as, for instance, renewing the brake pads or calipers, brake discs, hoses or the tandem master cylinder with brake booster servo, or if the parking brake has to be repaired, it is sufficient afterward to simply check that the ABS is operating.
      Caution:
      • During welding work, the plug of the electronic control unit must always be disconnected
      • If body repair is performed, note that the electronic control unit can withstand temperatures up to 203° F (95° C) for short periods only, and up to 185° F ( 85° C) for a maximum of approximately 2 hours.
      • If the car's battery is removed, check most carefully after installing the battery again that the terminals are tightened correctly.
      Notes
      Various methods of brake pressure regulation are feasible, so that anti locking systems differ according to the methods or their combinations used and the equipment thus installed.
      A fundamental distinction is made between anti lock devices for the rear axle alone and those for all four wheels. In addition, the regulating system can operate on both brakes of each axle together or separately, or both methods con be combined. Furthermore, axle regulation can employ the "select low" principle, in which the wheel with the poorer level of traction or transmission of forces determines the cut in point, or alternatively, the "select high" principle, in which the signal from the wheel with the higher level of traction is adopted.
      As stated earlier, E30's use individual wheel control at the front wheels and the "select low" principle at the rear axle, with a detector in each rear wheel. "Select low" is considered to offer better stability.
      Special note about 325iX vehicles
      Engine braking torque is reduced during low friction / poor traction ABS operation and at road speeds above 15 mph. On cue from the ABS control unit, the Motronic control unit (DME) will position the idle control valve to limit engine braking to an acceptable level. This info is transferred from Pin 3 of the ABS control unit to pin 50 of the DME.
      The torque control feature is ended when the ABS operation is complete or when the clutch pedal is depressed. A dedicated second clutch switch is used for this purpose.
      Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
      • FunfGan
        • Jan 2011
        • 4958
        #33
        Most likely. I tried locking them in the rain when I had my bottle caps with crap summer tires on, and thats the only time I got them too.
        Go here be happy!
        Ratchet Garage e30 V8 build.
          #34
          That probably says more about the brake pads you are using than the tires/wheels. With appropriate pads, an E30 can lock up r-comps in the dry. R-comps have way more grip than any street tire. So if you can't get into ABS, your pads aren't providing enough friction.
          • broke30
            • May 2007
            • 1019
            #35
            I know this is a touchy subject with some, but every one of my e30's have abs removed. All that needs to be done is the removal of the unit, computer, etc, as well as the lines that go to the soft lines for the front calipers. Then, rebend lines for the front two, and t those into the front fitting on the master. Then a short line to the valve leading to the rear and that's it.
            Honestly, the pedal feel is incredible, especially with ss brake lines. However, I would say that certain weather conditions do not warrant a car without abs.
            Max
            • FunfGan
              • Jan 2011
              • 4958
              #36
              I did get new pads a month or so before I took her off the road, so maybe that was the issue? I'm searching for a bbk now.
              Go here be happy!
              • george graves
                • 20003
                #37
                Max
                I'd love a write up. With my e30 being a daily driver, it would be nice for this to be a weekend project.
                Originally posted by Matt-B
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5284
                  #38
                  Honestly, I don't know what car everyone else is driving, but I have an e30. And when I'm braking, and I get to the threshold where ABS kicks in I get scared because I stop decelerating.
                  I've even gone out of the way to use ABS "properly" by not lifting off the brake when it activates, but the car just ceases to slow down at any reasonable speed.
                  I understand the benefits of ABS, but ABS has come a long ways since the 80s, and the ABS on our cars is completely obsolete compared to a modern ABS system.
                  The day will come when I ditch my ABS, the only question is when.
                  Originally posted by priapism
                  Originally posted by shameson
                  • FunfGan
                    • Jan 2011
                    • 4958
                    #39
                    Easiest way is to just pull the plug.
                    Go here be happy!
                    • Jonny Cash
                      • 1763
                      #40
                      Heres how i did it. Used the splitter from the rear lines.
                      -Jay
                      2014 NASA FL se30 champ #81
                      2001 se46 3 year plan in progress
                      • smooth
                        • Apr 2005
                        • 1940
                        #41
                        The only thing remotely true in this post is that your brakes are apparently malfunctioning.
                        But that's got nothing to do with the design of an E30's ABS system.
                        Out of curiosity what do you think when you write that the ABS system is primitive?
                        What does that mean to you when you write it?
                        • nrubenstein
                          • 3148
                          #42
                          This means that your system is not working properly.
                          I mean, sure, compared to my E46 M3's system, the E30 ABS is absolutely primitive. It can't pulse as often and the three channel nature is arguably more primitive. (In reality, there isn't a real advantage to four channel ABS other than as part of traction control.) But, uh, it works quite well.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • Stoner Sam23
                            • 186
                            #43
                            I do know how Northern feels because apparently my ABS is malfunctioning as well. It does feel like when it kicks in it lets off the brakes.
                            • smooth
                              • Apr 2005
                              • 1940
                              #44
                              It's supposed to let off the brakes because if it didn't your tires would stop turning and the rubber will skid across the top of the asphalt until you smack the car, the curb, or the tree.
                              What it's not supposed to do is fail to slow you down at all. That's asinine and clearly broken.
                              It's also not supposed to magically work without any kind of maintenance for decades. But how often have you been under there cleaning and inspecting and lubing your braking system?
                              I mean here you have in your hands a high performance engine in a tiny, sporty coupe, but neglecting the thing that prevents you from colliding with other vehicles and whatever else--your brakes. And rather than figure out why this matchbox car isn't stopping on a dime you're arguing to rip out one of modern vehicular safety's greatest accomplishments--ABS.
                              If you disconnect this system and still don't bother rebuilding your calipers and making sure everything is sealing properly and lubed up, the best case scenario is that you'll lock your wheels where you previously weren't slowing down. So even if you are not slowing down at all because of a malfunctioning or primitive ABS, you still scared the crap out of yourself, yanked the wheel around the thing you were barreling into, and slowed down for the rest of your drive home. That's far better than slamming into something, don't you think?
                              You can this for yourselves in an empty parking lot.
                              Try it with the ABS and then try it with the ABS unplugged.
                              • FunfGan
                                • Jan 2011
                                • 4958
                                #45
                                lulz.
                                Somebody has sure been hit from behind too many times...
                                Go here be happy!
