abs delete? worth it?
  • smooth
    • Apr 2005
    • 1940
    #61
    Originally posted by Northern
    I like how a lot of people in this thread believe that once your wheels lock up, you instantly hit a car/tree/explode/die.
    You can steer while braking anyways, you just use one input at a time. ABS was designed to simplify the process for your average soccer mom to blindly mash the brake and swing the wheel to avoid the car in front.
    Just to be clear, I'm not saying that ABS will or won't save someone from collisions.
    I'm saying that ignoring routine caliper maintenance will result in unsafe braking results.
    I could be wrong but my suspicion is that people are driving along and their ABS light is not on but their ABS is not activating. So many people will conclude that their ABS is too broken or primitive to even know that it's not functioning. But it is...at least it's trying to but the calipers are frozen so can only do so much.
    There's more to brakes than just fluid and pads...not a lot more when you get right down to it. Maybe an hour or two and a tube of grease at a minimum. So much attention is poured into going faster so I'm trying to encourage people to put some work into making sure they can slow down properly, too.
    Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
    • u3b3rg33k
      • Jan 2010
      • 2452
      #62
      Originally posted by nando
      actually, what it does is keep the car going straight even if the front left and front right have vastly different amounts of traction. it's not going to send your car into a ditch.
      do a high speed slalom in the rain and see if you like ABS then. You don't always want to corner before the turn (or neccesarily have time). :)
      I meant user selectable individual brakes, not IWABS. Panic braking on only one side of a vehicle WILL turn it.
      I put more time into my brakes before an event than I do the engine - all the love it gets is the occasional VJ and fluids.
      Ich gehöre nicht zur Baader-Meinhof Gruppe
      Originally posted by Top Gear
      Just imagine waking up and remembering you're Mexican.
      Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
      • schtozo
        • 1455
        #63
        Sorry to thread jack! But im having some problems with the bias valve an need to deactivate the ABS pump temporarly, how can i achieve this? I removed the black plastic cover thats on the pump and found two relays, one black that says 12v and the other is a smaller silver colored that has all the numbers 30,11,87,87...
        Please advice!
        One of the best threads you will ever read
        http://www.r3vlimited.com/board/showthread.php?t=221813
        Nice trailer of my e30
        http://www.youtube.com/watch?v=TTjtG...e_gdata_player
        If i sold you something please leave feedback here
        http://www.r3vlimited.com/board/showthread.php?t=217142
        • Bearmw
          • 1323
          #64
          There is no right or wrong to having ABS. All human activity involves risk and all humans are at time irrational or we wouldn't survive at all.
          Now ask these and other questions: Do I smoke, do drugs, get too much sun, eat poorly, consume too many carcinogens, drive an old classic car without modern safety features, ride a motorcycle or bike, insult the wrong person, hike in the mountains, get enough sleep, save enough money, drive too fast, follow too close, exercise enough, have unprotected sex, have poisonous reptiles as pets, have the right partner, inspected my tires.....
          Do your own cost/benefit analysis and realize you may be wrong whatever your decision but just be mentally prepared to live with unintended consequences.
          If I get rearended by someone regardless of whether they have ABS or not I hope that I'm not seriously injured and they have deep pockets.
          If I rearend someone I hope they are not seriously injured and.....see ya;)
          • u3b3rg33k
            • Jan 2010
            • 2452
            #65
            schtozo, start your own thread, and pull the ABS fuse.
            WTF is this? You come into this thread and post about how not having an opinion is cool? grow a pair. no communal CYA needed.
            Thanks so very much for your time, it's been a pleasure. Wait, I'm sorry. i mean STFU.
            • TobyB
              • 5296
              #66
              I've raced E30s with and without it. It's OK. It DOES prevent square tires.
              It DOESN'T alter physics.
              However, the E30 into '86 had a 20mm master cylinder, with and without ABS.
              With a 33 mm rear and 48 mm front caliper, that put the brake split at 70% front,
              30% rear, which is safe on the street, and according to Tilton (who sell racing brakes)
              also a good starting place for a race car with sticky tires.
              Sometime during '86, or in early '87, the ABS cars get a split 17/22mm master, changing
              the balance to 44% rear, 56% front. This is good at stopping the car in moderate- force
              stops, but when you get toward threshold braking, the rears will now lock first.
              ABS catches this, unloads the rears, and lets the fronts keep working.
              With an E30, you can still ADD a bit more brake pressure, and you'll still get more front brake
              even though the rears are thumping away. This took some laps to get used to.
              If you now unhook ABS, you have a car that will lock the rears first in a panic stop.
              This means you either have to modulate brakes or spin the car. The first results in a longer
              stopping distance, the second results in the possibility of turning a frontal impact
              into a side impact.
              So if you decide to delete the ABS or leave it non- functioning,
              it's probably a good idea to make sure you have the earlier 20mm master. And the
              accompanying check and restrictor valves.
              jus' sayin'...
              t
              who measured things himself.
              • nrubenstein
                • 3148
                #67
                into a side impact.
                jus' sayin'...
                t
                Anybody who deletes ABS without adding a bias valve is an idiot, IMHO. :)
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                • homegrone30
                  • Jun 2007
                  • 1449
                  #68
                  How so? A proportioning valve only adjusts line pressure. Cars have ran without abs or bias valves for years. So why is it moronic to not use one with an abs delete? I cut my abs out and have not had one problem since. Of course I would love to install a proprtioning valve but I dont see why it is needed.
                    • 34844
                    #69
                    because the proportioning of the ABS system is different than a non-ABS one.
                      #70
                      I don't think so. To the best of my knowledge there is no proportioning in the ABS unit on an E30. There is a bias valve for the rear brakes, which is responsible for the proportioning.
                      I've added ABS to a car and removed ABS from from a car. In neither case was there any difference in brake bias.
                      • homegrone30
                        • Jun 2007
                        • 1449
                        #71
                        Ding ding ding!
                        • nrubenstein
                          • 3148
                          #72
                          You read that wrong. The bias of the non-ABS cars was different - i.e. more front biased. This has nothing to do with the ABS unit itself.
                          So, a factory non-ABS car will have lots of front bias for "safety." If you're going to insist on fucking with your brakes, you should at least set them up properly and get the bias right for your car.
                          • Bearmw
                            • 1323
                            #73
                            The ABS delete question has been discussed ad naseum with no single "answer". Thought I would give you my take on the question so lighten up Francis.
                            • homegrone30
                              • Jun 2007
                              • 1449
                              #74
                              [QUOTE=nrubenstein;3034709]You read that wrong. The bias of the non-ABS cars was different - i.e. more front biased. This has nothing to do with the ABS unit itself.
                              • homegrone30
                                • Jun 2007
                                • 1449
                                #75
                                Damn tapatalk! Your right. But i think the easier solution would just be to swap in a non abs maate
