The cheapest performance brake refresh you ever did see
  • Pheret
    • Jun 2012
    • 44
    Great post, saved me tons on my DD. Ordered front/rear Pads, Rotors, Caliper rebuild kits, both rear hoses, pressure regulator, and sensors for just over $200!
    Found coupon code: SpecE30 for 5% off your order, plus over $50 is free shipping.
    1997 Estoril M3 Coupe 5spd
    1989 Alpine 325iS Coupe 5spd
    • Panici
      • Dec 2009
      • 2570
      Sorry to bump an old thread.
      I'm looking to order the same setup as the OP. Will it work on my '86?
      Also, what is a "Girling" brake system? And how can I tell if my '86 325e has it? It seems to make a difference for caliper rebuild kits.
      Thanks!
      • mbonanni
        • Sep 2011
        • 6236
        Yes this will work for your '86 325es.
        Someone correct me if I am wrong, but I believe there are two diffeent brand/type of calipers that came on e30's. One is Girling and one is ATE iirc. You should be able to just take a look at the caliper and see which ones they are. Check both front and rear to see what each ones says, as mine were different.
