RX7 BBK Big Brake Kit Pad Options - Track
  • akorcovelos
    • Dec 2006
    • 1149
    Im running HP+ at track days, never had problems with fade. We only run 10ish lap sessions, but even after 10 hard laps they don't fade at all.
    2012 MCSCC/NSSCC CP class champ
    HSAX Instructor
    • dinanm3atl
      • Feb 2007
      • 7305
      HP+ is not a track pad. It cannot withstand the temps. Heard this before and not sure how someone is lapping at speed and using HP+.
      Originally posted by 2002maniac
      ouch. I've had good luck with HT-10 if that helps
      Yah. Might look into switching back to Hawk.
      • akorcovelos
        • Dec 2006
        • 1149
        All I can do is relate my experience. 10+ hot laps at a time and no fade. Others are saying the same thing, so track pad or not they work for me and apparently others.
        HSAX Instructor
        • dinanm3atl
          • Feb 2007
          • 7305
          On what track? What speeds? What tires? They simply are not 'track pads'.
          • Fernflex
            • 264
            I was running Hp+ with the stock calipers and after 3-4 laps the brakes started to fade. Temps around 95+ here in Puerto Rico.
            Now Im going to use HT-10 with the Rx7 calipers, slotted/cross drill brakes and brake ducts.
            Please Rate Me:
            http://www.r3vlimited.com/board/show...35#post3283535
            ________________
            1987 332i Track Car (253whp)
            __________________
            • dinanm3atl
              • Feb 2007
              • 7305
              This is more my experience.
              • akorcovelos
                • Dec 2006
                • 1149
                Black Hawk Farms, Autobahn Country Club both north and south tracks, speeds topping at ~100 in the longer straights, running T1Rs.
                HSAX Instructor
                • Wanganstyle
                  • 2828
                  Originally posted by dinanm3atl
                  Some of their track pads are 300 dollars an axle... PFC06 are 125 dollars for the front axle. Has to be some of the stuff I am familiar with. Not sure how I am going to match up pads from these two companies.
                  Japanese brakes, best pads will be from Japan.
                  I've tracked a fc3s and fd3s and my bmw at the same track, have personally used hp+, project mu, ebc pads.
                  For the Japanese high end stuff it's expensive. But so are hawk blue race pads, ferrodo, wtc etc etc.
                  Racing + budget brake pads that can take non-budget slicks?
                  Only thing budget in the equation can be local steel blank rotors (for "warrenty")
                  For an e30 with slicks have you tried cobalt friction? Those are quite aggressive.
                  For a heavier e36m with full slicks and full weight ebc yellow could take 2-3 hot laps at Laguna Seca.
                  • dinanm3atl
                    • Feb 2007
                    • 7305
                    For the Japanese high end stuff it's expensive. But so are hawk blue race pads...
                    Thanks for the additional information. I'll look into those. 25 minute sessions E30 on slicks there is one corner that is after hard braking there is a little fade. I know it is there so I am prepared for it and it's more of a trail braking corner anyways but like to be setup better if possible.
                    Yah. I am seeing 130-135mph into 10A at Road Atlanta. Then two turns later seeing 100mph again.
                    • akorcovelos
                      • Dec 2006
                      • 1149
                      Fair enough. :)
                      HSAX Instructor
                      • ed94r
                        • Mar 2004
                        • 382
                        Raybestos ST-43 were a much better track pad for me than the HT-10's. They are twice as much $$, but will appear to last 3X more than HT-10's. I am able to carry the brakes in deeper, for less time, than the HT-10's lap after lap (VIR Full).
                        RX-7 fronts+ST43
                        Meyle Rotors
                        Stock rear+PFC06's
                        ATE Blue
                        No ducting.
                        I got them from LPI in California.
                        Ed
                        1988 E30/S50...now with S52; Track
                        1994 Miata R; ES Solo2
                        1998 Lexus LX470; Wife (Slee'd anyway)
                        2002 BMW 530i; A+ Commuter
                        2002 BMW 325iT; Sport/Premium 5-speed
                        2011 21' EconoTrailer
                        • 2002maniac
                          • 4260
                          RX-7 fronts+ST43
                          Meyle Rotors
                          Stock rear+PFC06's
                          ATE Blue
                          No ducting.
                          Ed
                          Aren't you S50 swapped too? What tires do you run at the track?
                          • xxlbimmer
                            • Dec 2010
                            • 156
                            When I talked to Performance Friction 4 weeks ago they stated that they are no longer supporting the second gen RX7 front calipers.
                            Iam becoming a dealer for CL Brakes, It is a French company heavily into GP and Super bikes, and RALLY cars. Thier stuff is big bucks but reviews on EVo, STi, Lotus boards has been incredible. I will be putting a set on my M42/E30 racecar as soon as it's done. Probably by mid summer. The US distibutor for them, supplies a number of Cup, truck etc teams with CL products and AP calipers.
                            Chris Leone
                            chrisleonemotorsports.com
                            rollcages and fabrication
                            Remember cross threading is the only thing stronger than loctite!!
                            • dinanm3atl
                              • Feb 2007
                              • 7305
                              That was the vibe I was getting. I find it odd because they still support the tiny E30 market and produce all the newest pad compounds. Seems the RX7 caliper is very popular swap. From Volvos to E30s.
                              • ed94r
                                • Mar 2004
                                • 382
                                Yes,238rwhp. RA-1's.
