How do you take off a stripped Hex screw holding the rotors?
  • S13_E30
    • 309
    the hex screw holding on my rear rotors are completely fffffffed. Is there any possible way to get them off? i just sat,stared at the rotor and put my head down out of sadness when i say this....please help me be happy again!...and if no one knows of a solution..i might just replace the entire trailing arm and rotors.
  • Ryane30guy
    • Aug 2011
    • 54
    I usually drill them out then after taking the rotor off you can remove it with some vice grips and wd40
    • MaksV
      • 1042
      Drill it out.
      CHEAP REBUILT INJECTORS
      Need Quality Brakes? BimmerBrakes has it!
      For anything Else go with BluntTech!
      • S13_E30
        • 309
        Originally posted by MaksV
        Drill it out.
        Thanks. Drill it out it is then.
        @ MaksV , saw the link to bimmer brakes....hmmm might order some now :) i love how it all falls together
        • MaksV
          • 1042
          Ya just tell Anthony I sent you, get a little extra off.
          • S13_E30
            • 309
            Sure will, gonna see what else i can buy from them, i was only going to change out the wheel bearings but since everything is basically going to be off might as well replace some things....solid trailing arm and subframe bushings, solid diff mount, new axles...might get coilovers soon, replace diff fuild and gasket.
            • 2002maniac
              • 4260
              drill!
              • IxTech
                • 471
                Pound a torx bit into it! Haha
                http://r3vlimited.com/board/showthread.php?t=201774
                • bmwguy325is
                  • May 2011
                  • 1263
                  Drill it out.
                  This may be easier for me as I have no backing plates. I drilled off the head of the screw so there was a stub to grab with vice grips.
                  I was also doing rotors and I pouned them off with a 3lb hammer.
                  sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                  The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                  • kronus
                    • Apr 2008
                    • 13032
                    How to prevent this problem: replace these little fuckers when doing brakes and don't overtighten them, nominal torque is like 18 ft-lbs and they're held in by the wheel anyway. Put anti-seize on them, too.
                    cars beep boop
                    • willworkfore30s
                      • Aug 2011
                      • 1090
                      Autozone sells bolts that are meant to replace the ones that hold the two pieces of your brake caliper together, but they fit like the set screws only with a hex head that is easier to remove. Drill out your stuck ones and then replace them with these or just don't use any once you remove the bad ones.
                      Using the caliper bolts only works if your wheels are recessed in the area that goes over the set screw hole. My wheels are but my spacers aren't so until I can carve out some room in them I am running no set screw
                        • 37833
                        Or you could run the correct set screw.
                        Grover Beach, California
                        BimmerHeads.com
                          • 34844
                          I use antiseize, and don't overtighten them.
                          I've reused the same set screws for the past 5+ years. I have new ones but there's been no reason to replace them.
                          pretty sure the torque is 18 in-lbs, not ft-lbs. you can overtorque these with your pinky.
                          • iansane
                            • 1342
                            Impact driver.
                            84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                            • S13_E30
                              • 309
                              I ended up using a really small trox socket gave it a few love taps and unscrewed it. Heard these arent necessary to keep on there, the lug bolts keep the rotors in place.
