whats the trick???
  • mrsleeve
    • Mar 2005
    • 16387
    whats the trick???
    OK after searching for awhile I cant find any thing.
    How the hell do you get the front shock nut tight? the on that sits down in the strut bearing, you know the one that holds the strut togeather. I cant get it too tighten down to where it need to be, because I have no way to turn the nut and keep the shock shaft from turning.
    thanks
    RJ
    Originally posted by Fusion
    William Pitt-
  • alex
    • 2024
    thanks
    RJ
    Put the car on the ground, and hold the nut with something like a big screwdriver or needle nose pliers and rotate the shaft of the shock to tighten that nut.
    • Jordan
      • 12916
      Impact gun tightens it in .04 seconds.
      https://mtechniqueabs.com/
      • PeaveyBassist
        • Sep 2004
        • 3511
        If he is asking this question... I am sure he has an impact gun to use. And my impact tightens it in .02 seconds. Suck on that one.
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • alex
          • 2024
          Not supposed to use an impact with Konis by the way. Voids the warranty.
          Will, go to sleep, kids time is over. You don't even have an impact.
          • PeaveyBassist
            • Sep 2004
            • 3511
            Theres the whining again... I use impacts at work all the time :( Why dont you go pick on somebody your own size while I go cry in the corner? ...
            Will
            DaveCN = Old Man
            • Jordan
              • 12916
              Well since I'm pretty sure we are talking about a solid piston Bilstein/Boge type deal, I don't think its an issue.
              I wouldn't use a Impact on an adjustable shock as it would potentially wreck its shit.
              • mrsleeve
                • Mar 2005
                • 16387
                Will
                Yes I have an impact, is a ingersoll 2135Ti good enough?
                All it dose is spin the shock shaft also, this is why I asked the question
                William Pitt-
                • 2002maniac
                  • 4260
                  It is tight enough
                  • RobertK
                    Kicked cancer's ASS.
                    • Jun 2005
                    • 5864
                    Originally posted by 2002maniac
                    It is tight enough
                    Not nessesarily, I had the same issue with my mom's E36 when I put new shocks on her car. Sometimes the impact wrench would just spin the shaft too.
                    It's easy as pie..
                    What I did was I had a friend hold the shaft of the shock piston with one of those jar opening grippy pads (you know.. that non slip rubbery material)while I turned the bolt with my ratchet as soon as you start to notice that it's tightening up keep the momentum up to make sure you get the bolt nice and snug.
                    • cthulu703
                      • Oct 2004
                      • 288
                      I used two people, two strap wrenches, and a clicker type torque wrench. Done off the car. Shade-tree all the way.
                        • 34844
                        I never had any trouble doing mine with the car on the ground, didn't have to hold the shaft at all. oh well..
                        • ///M Powered
                          • Jan 2004
                          • 1109
                          Same.
                          • mrsleeve
                            • Mar 2005
                            • 16387
                            thanks guys, I em. Strap wrench on the shock shaft an my impact got them. I should have though tof it sooner but it was late when I postd this ?.
                            William Pitt-
