Camber Problem
  • EuroTrash///E30
    • 128
    Camber Problem
    I know this isn't the right spot for this thread, but for some reason I can't post in the suspension section. Here is my problem. I have an 87 325e on stock suspension. My rear driver side tire has very bad camber wear. I put new tires on it in march, and it's already bad again. I changed all the wheel bearings on my car and it still has camber. Any suggestions on what could be causing this?
  • gp.plus
    • 416
    Something is bent, either trailing arm, subframe, or possibly the car itself. Get out a measuring tape and start comparing measurements from side to side, choose a static point to measure from to ensure good data. Look for signs of prior accident repair. I can email you the chassis measurement sheets if you like. See example below..
    • EuroTrash///E30
      • 128
      Yeah, email them to me. ThroneOfLunacy@aol.com
      • gp.plus
        • 416
        Sent, 8 total I numbered two #5 by accident but they are different. Good luck
        • akorcovelos
          • Dec 2006
          • 1149
          Can you send me those as well?
          Thanks!
          2012 MCSCC/NSSCC CP class champ
          HSAX Instructor
          • gp.plus
            • 416
            Sent
            • akorcovelos
              • Dec 2006
              • 1149
              Got them, thanks!
              HSAX Instructor
                • 34844
                could also be badly worn rubber bushings (trailing arm, subframe, diff)
                the subframe and trailing arm are also prone to bending.
                • EuroTrash///E30
                  • 128
                  It was the trailing arm bushing, its all better now. Thanks for your help
                  • Smelser
                    • Feb 2011
                    • 633
                    Any chance i can get that email too please to csmelser@xplornet.com It would help us great in the future.
                    sigpic1984 318i Total conversion to a DIRT race car.
                    Check out our build on facebook @ www.facebook.com/brewstermotorsports
                    • gp.plus
                      • 416
                      Sent. Maybe someone can host these so they will be available to everyone.
                      • drumad
                        • Aug 2009
                        • 1700
                        we really should have a public google doc acct
                        2008 335i - n54b30
                        1991 318i - m52b28
                        1994 fzj80 - LAND CRUSHER
                        • gp.plus
                          • 416
                          I have sent them to a member who is going to host them so everyone has access. I would just like to point out that I did not scan these in or obtain the actual sheets myself, I merely found them on the Internet and saved the jpegs. So thanks to whoever did the initial scans, these are great to have.
                          • TobyB
                            • 5296
                            did these get hosted? Mr 'thinks he's building a race car' thinks they could be very
                            useful, both before and after...
                            thanks!
                            t
