Installing new e-brake cables
  • wildstoats
    • Sep 2007
    • 896
    I hate to even ask about this because I'm sure it's something simple but I can't see how to install new e-brake cables. I had to cut the old ones out and then use vice grips and pliers to get the ends out of the tubes, no problem there. I just can't figure out how to get the cable back in, i tried sliding them in from back to front but the threaded portion doesn't fit in the tube, close but not quite. I can't see any way to disassemble the cable itself as everything looks crimped together. Any tips?
  • TobyB
    • 5280
    It should slide up the tube. You have to take the nut off...
    Did the end come out of the welded- on tube? Often they rust on, and the end looks just
    like a bit of the tube. Your old ones should have had end caps on both ends- I bet your
    end caps are still stuck to the tubes under the car.
    hth
    t
    • wildstoats
      • Sep 2007
      • 896
      Yeah, it was a pain to get the ends out because of how corroded they were but I'm nearly certain I got all the junk out of there. Perhaps I will snap a photo when I get home to illustrate the problem.
      • wildstoats
        • Sep 2007
        • 896
        Ok, well here's what I'm dealing with, I ordered part #34-41-1-158-421-M4 from Pelican, pretty standard. I've never had this apart before so I'm not sure what it is supposed to look like. Is part of the old end still stuck? This is what the tube looks like:
        • FredK
          • 14762
          Yes. That is the old barrel that is stuck in the metal tube, so you'll need to remove it. Soak it in some penetrant, and twist it free. Light hammering helps.
          • wildstoats
            • Sep 2007
            • 896
            In case anyone wanted some closure I did get this fixed. All's well, ponies, etc.
