all 4 brakes locking up...
  • bimmerhodge
    • Jun 2012
    • 31
    I have a 1991 318is. This summer I swapped in an OBDI M52B28 with a 50k mile ZF trans. There are still some kinks to work out, but it's an awesome car so far.
    The real reason I'm posting:
    I'm having an interesting brake problem.
    When I did my engine swap, I drilled new holes thus relocating the booster to the drivers side .5". All seemed well. I can drive on the highway long distance no problem. But. If I rip around town for say 30 mins (using the brakes more often than highway, obviously) ALL FOUR BRAKES LOCK UP. Brake pedal/clevis/pushrod seem to be adjusted correctly. I even threaded the pushrod further out than the manual suggests this morning. After around 30 mins of driving, I pulled into the driveway with all 4 brakes hung up. Brake booster doesn't seem to have any leaks, I tested by removing the vacuum hose on the front and plugging it, idles just the same. If you have any ideas... please share. I'll probably buy a master and booster from gunmetalgrey... but just in case anyone has a clue I figured I'd ask.
    If more information is needed, I'm sure I can get it for you.
  • Todd Black 88
    • Oct 2007
    • 3449
    You saying they are sticking on?
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • bimmerhodge
      • Jun 2012
      • 31
      Yep.
      • mattdk318i
        • Jun 2006
        • 3953
        had the exact same problem. the booster rod is kicked too far to one side. Meaning its binding on the return. I learned my lesson with this. I would break down and snag a e21 or IX booster
        Since the holes were slotted and the location on the pedal hasnt changed.
        • bimmerhodge
          • Jun 2012
          • 31
          As far as i can tell that isn't it... Im not running the stock clevis, it also is made to be over .5"
          • mattdk318i
            • Jun 2006
            • 3953
            alrighty
            • bimmerhodge
              • Jun 2012
              • 31
              I appreciate it and ill still check it out next time i get a chance. Ideas are what i need and thats what you gave me. Thanks.
              • mattdk318i
                • Jun 2006
                • 3953
                no prob man. hope you figure it out
                • MaksV
                  • 1042
                  I had this happen. Broke the booster. Check the input shaft, if you can pull it out its the booster.
                  CHEAP REBUILT INJECTORS
                  Need Quality Brakes? BimmerBrakes has it!
                  For anything Else go with BluntTech!
                  • TobyB
                    • 5243
                    yeah, the master's not returning all the way to where the equalization ports
                    are open to the reservoir. For whatever reason...
                    t
                    • bimmerhodge
                      • Jun 2012
                      • 31
                      More info on that input shaft?
                      • bimmerhodge
                        • Jun 2012
                        • 31
                        New booster and master are in. Bleeding the brakes today. Fingers crossed!
                        • craiggroves91
                          • Oct 2009
                          • 3024
                          Sorry to bump this semi-old thread, but I am having lock up issues as well. Also have a relocated booster with modified clevis.
                          It seems to only be my front brakes that lock up
                          Did you ever get the issue fixed?
                          1989 BMW 325i SOLD
                          1998 BMW Estoril Blue e36 M3/4/5 SOLD
                          1987 BMW 325 (The Piece) SOLD
                          1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
