motor mounts not lining up with subframe.
  • J.Rizo
    • Aug 2012
    • 949
    and i'm running out of daylight.
    i have no idea what to do. i took my subframe off and everything was where it was supposed to go.
    do you guys know what trick i need to do to align them?
    i tried lifting the engine more but that just pulls it away.
    thanks in advance!
    @joshua.j.rizo
    Originally posted by SpasticDwarf
    Just remember next time you hear "late night when you need my love" I'm gonna be sitting somewhere way more bitchin' than you, driving or not.
    BUY MY BUGATTI WHEELS:
    http://www.r3vlimited.com/board/showthread.php?t=377693
    WRITEUP TO MY RHD SWAP:
    http://www.r3vlimited.com/board/showthread.php?t=371904
    The motor mounts are at an angle to the subframe, so the engine won't just drop in. You engage the motor mount stud on one side and then lever the engine over while lowering to get the other side in. This is easier to manage if the motor mounts are on the subframe, not on the engine brackets. And just starting the motor mount nuts on subframe helps.
    • J.Rizo
      • Aug 2012
      • 949
      okay so install the subframe, put the motor mounts on, then lower the engine only on one side onto the bolt on the motor mount, then the other? i know your answer was probably perfect but I'm over thinking it. (thanks a LOT by the way jlevie!)
      and i don't think i have enough play in my engine to do this. i cant move it side to side, just lift it up and down. I'm using an engine hoist. and i only detached my subframe. should i detach something else to get get more movement?
      for more detail; the bolt is BARELY on the subframe, and BARELY on the engine bracket, so it's almost there but it's at an angle so it's not going in.
      @joshua.j.rizo
        That is the basics. You will have to use a pry bar to push the engine toward the engaged mount to line up the other side. There is enough resilience in the motor mounts for this to work. This is easiest to accomplish with a helper. One person pries while the other works the hoist.
        • J.Rizo
          • Aug 2012
          • 949
          alright i have more confidence now. thanks again! so much!
          @joshua.j.rizo
          • Northern
            I like cupcakes & sh!tboxes
            • 5270
            +1 for what Jim said. It took me and a friend a whole evening to get new mounts on my car. 90% of that was trying to fit the new ones because they had much longer studs than the stock ones.
            Originally posted by priapism
            Originally posted by shameson
            • J.Rizo
              • Aug 2012
              • 949
              did you bolt motor mount onto engine bracket, then lower the bracket onto subframe, or put the motor mount on the subframe, and lower the bracket?
              @joshua.j.rizo
                It can be done either way, but it is much easier to see what you are doing when prying the engine over with the mounts bolted to the subframe.
                • lbreevesii
                  • Aug 2009
                  • 412
                  yup, just takes some finagling.
                  I generally put the mounts on the subframe, put a nut on them very loosely, have someone else lower the cherrypicker while i hold the mount in place and get one side on, the stud, then go to the other side and repeat. I can do it by myself now...
                  I don't always wreck cars, but when I do I wreck them into trees.
                  91' 318is S50 swap - The Black Widow
                  • Mr. Tasty
                    • Jul 2011
                    • 3421
                    I did this all with a low profile jack and I was by myself. It took a total of 5 minutes to line both the mounts up
                    2014 Alpine White 335i MSport
                    (Daily Driver)
                    Full Mperformance Aero
                    KW V2 Coilovers
                    VRSF Catless Downpipes
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      lol this dude is bad ass
