Will Trailing Arm Brace Interfere w/ Fuel Filler Hose?
  • Cinnabar325is
    • 1064
    My car is completely apart, so I can't just mock this up and check it out myself.
    I welded a transverse brace between the two "arms" of the rear trailing arm, much like the M Roadster/Coupe arms and the early E30 M3 DTM cars. The brace is about 2-3" aft of the RTABs.
    The trailing arms are finished and painted up nicely and it struck me that I might have an issue with the passenger side trailing arm brace interfering with the rubber hose that joins the filler neck to the gas tank.
    Anyone have this trouble before? Am I going to have to cut into my nicely refinished trailing arm and move the brace??
    I wish I had a helpful picture, but if I did, I wouldn't be asking the question.
    Thanks.
    '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
  • JGood
    • Jan 2004
    • 7959
    This link should help answer your questions.
    I'm guessing you'll probably need to redo them :(
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
      • 37833
      Wow, I never thought about that one!
      I don't think my old car had any issues with the M Coupe arms contacting the hose.
      Grover Beach, California
      BimmerHeads.com
      • Cinnabar325is
        • 1064
        Thanks for the link, that helped. And yes, I absolutely have to redo the right side arm. Crap.
        Driver's side should be okay.
        • 89AlpineM3
          • 548
          Look at my project thread I just posted pics of mine
          • Cinnabar325is
            • 1064
            Honestly it looks like you're going to have the same problem on the passenger side. Mine look just like yours.
            • 89AlpineM3
              • 548
              Jake on s14 , the linked thread, built them for me . We checked and it may rub but that's it he said only concern would be rubbing over time he said.
              • 89AlpineM3
                • 548
                All you need to do is channel it where the hose is if you want
                • Wishno87
                  • 6025
                  I did mine and they fit just fine. I will see if I can find pics.
                  • Cinnabar325is
                    • 1064
                    Let me post a pic of mine and see what guys think...
                    Will these clear the fuel hose?
                    • JGood
                      • Jan 2004
                      • 7959
                      Check this out, an interesting solution to the problem. This is for an s62 e30 build.
                      • 89AlpineM3
                        • 548
                        really the only way to tell is put it in and jack up the arm and see if it hits
                        • Cinnabar325is
                          • 1064
                          Perhaps, but like I said, the car is in pieces. Can't do that right now.
                          • Cletonius
                            • 2809
                            Looks like a good solution. Link to build thread?
                            - Josh
                            1990 325is
                            Need a shift boot?
                            Looking to buy shift boot frames, PM if you have one to sell
                            Here's what happens when you let the internet pick your license plate
                            • JGood
                              • Jan 2004
                              • 7959
