PSA: Do not use this method when doing trailing arm bushings
  • noid
    • 1537
    The rod WILL bend the two arms when pushing the bushings in/out (for me they bent while pushing bushings back in). The two arms that hold the bushings got closer by a significant amount. I was using a normal sized wrench, and normal nuts.
    I also found these similar experiences:
    :hitler: Lesson learned. Hopefully this serves as notice to others to avoid this bullshit.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • seatown88
    • 331
    this method will bend the arms if the proper size socket wrench is not used. The socket so press solely on the metal insert and not the entire TAB. If pressing on the metal insert the bushing comes out comes out very nicely. If pressing the entire bushing the all-thread/trailing arm will bend without removing the bushing. I found this out the hard way.
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      I just perforate the bushing with a small drillbit, then push it out with a large C clamp with sockets that fit in and over the TA slot. 3 Jaw puller works ok as well, but I always have issues with the teeth slipping off.
      Originally posted by priapism
      Originally posted by shameson
        You can get an RTAB tool (part RTABTL) from AKG for $35.
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          I used a GM ball joint removal tool for free from vato-zone, and a carefully selected socket.
          -Andy
          • TimKninja
            • 2131
            Holy Overly complicated batman....
            Large C-Clamp, 32mm Socket. heat up bushing as you press out..., Pressing the old bushing into the socket. Took me like 5 Minutes per bushing and if you've ever worked on an E30 you should have those 3 tools...
            1985 325e M50TU(Sold)
            1991 318is Slicktop (Sold)
            1990 325is Brilliantrot S50/5 Lug Swapped.
            1992 525i Manual shitbox Winter Beater
            • Northern
              • 5284
              I have not had much luck with this method, Gouged the trailing arm with the socket pretty nicely, and bent the T handle on the clamp, and eventually the threaded rod in the C clamp too.
              Bigger C-clamp needed I guess.
              • Balleristic31
                • Aug 2009
                • 4198
                I just burned mine out
                -NICK
                • noid
                  • 1537
                  The rod method got them out without bending the arms. Putting them back in using the same method bent the arms.
                  However, as the links I provided attest, the rod method can also easily bend the arms while removing the bushings also.
                  I might just use my industrial vise to push them in/out, that method worked well for subframe bushings.
                  • yeaseth
                    • Jul 2011
                    • 302
                    ew
                    benvideoproductions.com
                    http://www.youtube.com/watch?v=617yNrOrRfo&
                    • KVF
                      • 297
                      Fire out and polly in ftw!
                      • SkiFree
                        • Jun 2011
                        • 2766
                        Very easy, not messy way...
                        Torch the outside of the trailing arm where the bushings are until you start to see the bushings smoke, 1 or 2 wacks with a hammer and you're done. The heat softens the rubber to where the outer later of rubber comes close to melting, it lubricates itself and slides out easy.
                        Not messy like burning, and not potentially damaging like the threaded rod method (and a lot cheaper than some tool).
                        ADAMS Autosport
                        • enigmaticdream
                          • Jan 2010
                          • 572
                          Steel pipe bigger than the bushing, rod that goes throug a 3/8 rachet hole, 3 nuts, bunch of washers, and a socket slightly smaller than the bushing works. Costs about $5-10. Worked on 2 sets of arms. It is essentially a cheap clone of the AKG tool.
                          1986 911 Supercharged Frakenstrat/Stripped
                          1987 325is Delphin/Black (Olga)
                          1988 M3 Zinno/Natur (Elsa)
                          Manual or STFU
                          E30 Chapter of BMW Car Club of America
                          E30 Oktoberfest 2017
