Athough the rear susp. is considered not adjustable it is relatively simple to change it to compensate for lowering the rear. The camber and toe info is from: http://e30m3performance.com/tech_art...rves/index.htm
A 1" drop adds .875 degree N. camber. A 2" drop adds 1.75 deg N. camber. To correct for a 1" drop requires the rear trailing arm to have its mounts moved 1/4". The outer down or inner up or both to move in the those directions 1/8". For a 2" drop it is 1/2" or 1/4" split between the inner and outer.
For the trouble of installing BMW offset bushings or the IE kit, you can slot the mount holes and spot weld reinforcing washers or drilled plates at minimal cost. $100 for 4 BMW Bushings or $150 for 2 IE kits.
This requires dropping the subframe for access to the holes with a die grinder. One side at a time should work.
This approach is not for the faint of heart or inexperienced and requires access to air tools and a mig welder.
I'm such noob that don't know shit, pleas explain if you can.
