Strange CAB, which way to orient in lollipop?
  • shaferbm
    • 615
    I'm not sure how to press this into the lollipop. There is an arrow that points near the edge, which at first I assumed was towards what would be the top of the car when properly. Looking at it, it seems like there could be other positions to orient it. Does anyone know?
    -'87 325 - ratbox swap http://www.r3vlimited.com/board/show...77#post3250277 << Check out my Wanted thread
  • shaferbm
    • 615
    • dude8383
      • Jan 2005
      • 10387
      Granted that its an M3 bushing... the same instructions can be followed.
      • shaferbm
        • 615
        My question is how I need to orient the bushing inside the lollipop. The procedure is just fine. Which is more ideal/ proper: having the thicker section run vertically or horizontally? I'm trying to imagine the forces it will be under, and it seems to me that most of the forces will be on y-axis.
        These bushings are different than the OEM ones, so I have no point of reference.
        • LJ851
          • 7919
          Uhh, line the arrow up with the casting mark like you do with all of them?
          Lorin
          The M30 is God's engine.
          • dude8383
            • Jan 2005
            • 10387
            Um. If you'd read the whole guide he does point out how the arrows should be aligned. Like I said, the bushing he used are M3 offsets... but you could still utilize his DIY for your purposes.
            • shaferbm
              • 615
              I Didn't realize there were casting marks. Note taken. Thanks for the hep guys.
              • digger
                • Nov 2005
                • 6199
                i assume the bush needs to be centered on the lollipop when pressing them in?
                shown here is flush on 1 side and proud of the other
                • efficient
                  • Feb 2012
                  • 3312
                  I did mine so that there are 2 equal lips sticking out of each side ^
                  Been like that for over a year
                  • petrolhead
                    • 421
                    It's supposed to be installed so that arrows point toward the centre of the car. In braking, rear end of the control arm wants to move toward gear box. That bush is designed to give less flexibility in that direction.
                    It matters very little if the bush isn't an equal amount over the lollipop on both sides. But yes it's supposed to be pressed "evenly".
                    ^ hope this isn't gibberish. My english is what it is..
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      You def want them centered....and yes, the arrow on the bushing needs to point to the nub on the casting.
                      Alice the Time Capsule
                      • digger
                        • Nov 2005
                        • 6199
                        yeah arrow and alignment is sorted and mine on the car are pretty close to centered but not sure if it mattered. its not hard to push them an extra 3mm.
                        thanks
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          thanks
                          There's a good 10-12mm of the CA sticking out when the bushing is centered (by eye) so being out a few mm is not going to matter.
