Removing rear hub from trailing arm
  • Andy348
    • Sep 2009
    • 688
    I'm doing a rear wheel bearing job and I can't get the hub out. I've got the half shaft out and an appropriate sized socket on the inside trying to hammer the hub out. Spent the last hour with no progress so right now it'll soak in penetrating oil overnight. Are there any easy(ier) ways to remove it?
  • reelizmpro
    • 9543
    rent a hub separator.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
      The right way to do this is with a Sir Tools B90 kit or equal, but it can be done on the car with a very heavy slide hammer and hub adapter. The hub has to be pulled off first to expose the snap ring that holds the bearing in. Once the hub is off the snap ring is removed and then the bearing pulled.
      • Andy348
        • Sep 2009
        • 688
        I rented this tool: http://s25.photobucket.com/user/m42s..._2417.jpg.html
        that the guy used in the DIY but didn't think I'd need a separate tool for the hub. I can check if the store would have a hub separator but I don't think I saw one in the catalogue.
        • Andy348
          • Sep 2009
          • 688
          • JonnyOg
            • Sep 2012
            • 191
            Hammer puller to get it out, super easy, and to press it back in was was successful with redi rod, two nuts and two blocks of metal with holes drilled through them.
