Front grind, moan, dragging noise last second of braking.
  • nickmcc92
    • Dec 2012
    • 442
    My driver side makes a grinding, dragging, moaning sound on the last second of braking and It rarely happens.
    What can it be?
  • mr ilia
    • May 2011
    • 582
    Worn out brake pads would usually make this type of noise.
    • ELVA164
      • 4861
      Yeah, do you have your sensors connected? If not, I would pop the wheels off and check the pad thickness. Another thought could be a sticky piston in the caliper, but the noise sounds a bit loud to be that.
      • nickmcc92
        • Dec 2012
        • 442
        Brakes are still good. I might have put the sensor on wrong but how would that cause a problem.
        I rotated the rotor with the wheel off and the rotor has an uneven spot and doesnt spin freely, but I still don't understand how it would cause this deep, dragging sound
        • nickmcc92
          • Dec 2012
          • 442
          Problem still not solved. Pads are good. Only visual problem is the spring looking rubber on the caliper is ripped, but how would that cause a problem?
          • jeffnhiscars
            • Jun 2011
            • 6011
            6 months is a long time to live with a brake problem and not be wrapped around a pole :-)
            The uneven spot could be a sign of a warped rotor and the rubber is a dust boot intended to protect your piston from being damaged. If it torn it will quickly result in a sticking caliper, reduced brake function and then a dysfunctional caliper.
            Time to dive in or take it to an expert
            Alice the Time Capsule
            • AndrewBird
              The Mad Scientist
              • 11898
              Guide pins could be sticking.
              Oh, and there will be a little bit of friction when you spin the wheel. The caliper moves away from the rotor when you let off the pedal, but not enough to clear completely, hence a slight mount of drag. Should still be able to turn the rotor pretty easily though. If not, the piston might be sticking.
              • nickmcc92
                • Dec 2012
                • 442
                I think you're right Nitro. I will be sure to replace them soon because I do have some wheel wheel friction. Thanks guys.
                • nickmcc92
                  • Dec 2012
                  • 442
                  I cleaned the guide pins and the noise hasn't come back.. yet. Will replace soon.
                  Thanks guys.
