So i bought a 323i euro e30 and its pretty beat up so i decided to make it into a drift car so i ended up welding the diff and started beating on it. about 3 days later i broke an axle on the OPPOSITE side on the hub CV. So i just thought OK its the original axle and just broke because of old age and stress. The second axle i put in broke because of an instalation error 15 secs after installing. The third axle i had to shake weight it into the hub far enough to pull the rest through with the bolt. That broke 1 day later on the outer CV joint where the hub is.
I honestly dont know why im breaking the axles. The welded diff doest help put it shouldnt cause it. People drift with welded diff all the time with no issues. Why is mine always breaking.?
DREWLIENTE
