HELP:where else could this noise be from?
  • NC325iC
    • Mar 2004
    • 6565
    ok, front right suspension, loud clunking noise. doesnt seem to be ball joints, doesnt seem to be sway mounts, cant find any visible damage, need help with this.
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    When my CAB blew up the control arm was flopping around inside by about 1/8th of an inch causing a knocking noise at the beginning when accelerating or braking, maybe something to look at? These were urethane ones where the sleve pushed out the back because I accidentally had them in backwards and it was metal knocking on metal but I suppose it could do the same thing with other styles if they were egged out.
    • NC325iC
      • Mar 2004
      • 6565
      theyre new stockers
      • NC325iC
        • Mar 2004
        • 6565
        i thnk its the sway endlinks, ill change them out tomorrow if possible
        • Scott314
          • Jan 2005
          • 287
          Yeah, definitely check the sway bar links. Also, when I had this problem, Jordan recommended that I check to see if a gland nut was loose.
          My fast says: traction control is for the faint of heart :evil:
          • Digitalwave
            is a poseur
            • 6292
            If both of the ball joints are tight make sure the gland nut on the top of the strut is TIGHT.
            RISING EDGE
            • NC325iC
              • Mar 2004
              • 6565
              ive checked the gland nut a few times, its definitely not loose, but i cant test if i can get it any tighter without taking the spring out afaik
              • bimmer8604
                • 3017
                just hit it with an impact gun. prob just loose.
                kyle
                1988 M3, 97 840, 99 XJ
                DILLIGAF
                • NC325iC
                  • Mar 2004
                  • 6565
                  gland nut holds the shock in place in the strut, correct
                  the top nut is tight i believe and i dont want to over tighten it
                  • NC325iC
                    • Mar 2004
                    • 6565
                    collar holding shock in strut FTW,
                    got a pair of channel locks around it and got 2-3 turns on it... yeah it was loose
