Polyurethane Bushings
- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plate -
This is true. You'll get 99% of the performance with no negatives in the way of 'ride comfort' reduction.
I have revshift rear trailing arm and subframe bushings. No complaints, except the shipping, that did take a while. Product is fine.
I really doubt on a mostly street car you'll notice a difference offset bushings or not. All the cool kids have them if that sways your decision.
Bilsteins are fine. I really don't know what that one guy meant by "outdated" but with almost any off the shelf spring they're fine at a good price point. If you ever need anything more than Bilstein Sports you'll already know what to look for.For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.Comment
Thanks guys
Hey you guys thanks alot for all ur input, i appreciate all the opinions. i read tru everything and i am in a gd position to make my choice now. if i am correct i think in one of the thread link a guy recommend to me or it might have been right in here, they say if u r using the poly bushes throughout u will need to do reinforcement, can anyone shed a little light on that issue, also y i decided poly is because it still has a bit of flex to it unlike the solid bushes that condor offers.
if you have more to shed on the matter plz do, i appreciate it.
Thanks
KirkComment
I had rev shift motor mounts. and they broke in the second night (about 10-20 miles of hard driving)
I have IE poly in the rear, and love them!!!!
go offset, if your on the street, install as directed. if your tracking, reverse the set up to make the car steer hard and quicker
sigpic1984 318i Total conversion to a DIRT race car.
Check out our build on facebook @ www.facebook.com/brewstermotorsportsComment
thanks
about the motor mounts and trans mount whats a gd brand to use?I had rev shift motor mounts. and they broke in the second night (about 10-20 miles of hard driving)
go offset, if your on the street, install as directed. if your tracking, reverse the set up to make the car steer hard and quickerComment
I've heard they re designed the mounts so they don't rip, i like IEs poly motor mounts though they seem to be a great compromiseI had rev shift motor mounts. and they broke in the second night (about 10-20 miles of hard driving)
go offset, if your on the street, install as directed. if your tracking, reverse the set up to make the car steer hard and quicker88 325is Five SpeedLachssilberComment
Wat.
No.
Don't do that.
Subframe reinforcement plates on the motor mount tabs aren't a bad idea, but I have delrin mounts and stock subframe, it hasn't broken yet.For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
New bushings are a good choice.
You should see if the suspension you're going to use recommends centered/offset. Ground control told me to use rubber offset e30 m3 cabs.- Josh
1990 325is
Need a shift boot?
Here's what happens when you let the internet pick your license plateComment
thanks, well to be honest i'll have to check on that. i am not doing no fancy coilover setup, which i would be glad to do but may cant afford it right now. So my choice is either koni's or bilstein with lowering springs. that's about it for suspension. so that is y i want to know if offset would be a gd choice or stick to the centered ones, also if i stick to th centered ones, is it ok to go poly also?Comment
keep in mind, I never get my car out of second gear. I hit the rev limiter, but second is it. high speed stability is not something I am concerned about. making the car "dartier" and more responsive to my input is better. if it oversteers I can correct that with more or less wedge (cant remember wich way to go to tighten or loosen the car at the moment)
my subfram is fine, but the revshift mounts ripped the bolt head right out of the plastic. wound up drilling them out and using a grade 8 bolt straight through the plastic (poly stuff) it has held so nice that we left it.
had stock rubber trans mounts till "the wedding incident" that jarred the car so hard it ripped them clear apart (3 months after the motor mounts ripped)
ended up building a new trans crossmember with a GM trans mount and more steel fabbed to fit the tranny. quicker and easier to replace in a pinch if we need to.
I just did bushings on my car. It had been 24 years and 130k miles since new. They were in okay shape. Rubber bushings will last quite a while.Comment
