Control arms
  • AndrewBird
    The Mad Scientist
    • 11897
    If only the passenger side is going bad, why are you replacing both arms?
    • Poorboyz
      • May 2012
      • 2117
      Are you sure you are tightening the 22mm nut the correct amount? I know that but on the passenger side is a pain in the a$$
      Sent from my Galaxy Nexus using Tapatalk
      Rebuilding since 07/06/2016
      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
      Poorboyz Feedback Thread
      • serdar255
        • Feb 2013
        • 395
        Just in case the other goes bad just a bit after honestly.
        I'd say so.
        image (10) by serdar.gurhan, on Flickr
        PM me for custom shift knobs and stickers!
        Originally posted by marshallnoise
        You ain't done working on a car unless you are bleeding.
        • Poorboyz
          • May 2012
          • 2117
          I just recently replaced my control arms and I took a pair of bmw oem arms and pressed out the old ball joints and pressed in some Lemfoerders. If you don't want to spend the money on new oem arms than why not go the route I did? Oem arms with oem replacements balljoints instead of of he cheaper version control arms you are using? What brand are you buying by the way?
          • IveGotIssues666
            • Oct 2006
            • 517
            Its important to make sure the ball joint isn't overtightened or undertightened as that will cause premature failure but also in rare cases the taper where the joint slides through the front subframe could very well be worn/oblong as well considering this issue seems to be re-occurring causing the joint to work fine for awhile at first.
            Jared
