offset REAR trailing arm bushings (got them from Australia)
  • skatefreak
    • Jan 2006
    • 116
    I got a set of offset bushings to fix my camber in rear and best part is they only cost me 15 bucks!!!! (thank god for Ebay)
    Here is a bad pic off the bay...will have better ones later.
    and the link....
    noltecsuspension.com
    and Part number
    n62188
  • rwh11385
    lance_entities
    • 18403
    hahahahahha
    those look so fucking ghetto.
    if you expect those to hold their positions...you're just silly
    • NC325iC
      • Mar 2004
      • 6565
      you got me so excited, dont trust ebay with impotant things
      • misterlance
        • Nov 2005
        • 170
        Originally posted by rwh11385
        hahahahahha
        They are fricken bolts and bushings man. I suppose if it said Eibach on the wrapper you would approve? Give me a break. I suppose the "big" manufacturers only use high tensil strength bolts and aircraft grade rubber?
        hahahahahaahh
          • 34847
          it doesn't matter who made it, that style of adjustable bushing is just no good.
          • misterlance
            • Nov 2005
            • 170
            I agree it is not the ideal track setup. But for the op's purpose, I am sure they will do fine and help with tire wear.
            • 1991 318is
              • Dec 2005
              • 786
              No big!
              IE adjusters used to require a spot weld to keep the settings. It's nothing a zap with the mig welder won't cure. The original settings are not adjustable. No reason to change them after correction either.
