Subframe bushing logistics.
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    OOOOhh yeah.. bigtime air hammers...
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • Eric Giles
      • 1068
      Why would anyone use an air hammer to knock the bolts out? Granted I have only had to removed a couple of rear subframes, but all you have to do is get a decent sized hammer and a couple of good whacks and the bolt is free.
      Eric Giles
      '20 M2 CS
      '04 M3
      '11 X5 35D
      '87 325is
      '91 325i Sport
      There are few things more expensive than a cheap BMW...
      • Garageaholic
        • Dec 2005
        • 5204
        yeah, well my bushings were fused onto the stud... it took alot to get those fuckers out.. i was pounding away at it for a good 25 minutes each....then it magically just fell right out..
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        • MarkH
          • Jun 2005
          • 65
          I used a 5 pound hammer and both of mine came out after a half dozen whacks. That was the easy part of changing the subframe bushings.
          • dirty30
            • 3098
            Originally posted by ak96ss
            +1
            It took me an hour on each side to remove the stub of the subframe bushing from the body. What a PITA that was.
            -ditto, airhammer FTW!!!!!!!!!!11!1
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              After doing about six cars I can now get the bushings out in a matter of minutes. All I need is a torch, an air chisle, and the optimum environment. Remove the subframe and put it in a vise, There are two dimples on each sleeve, those are what actually holds the bushing in. heat the rubber until the center sleeve separates, then cut the bushing sleeve away from the subframe by working the chisle in a downward angled motion. Once you have cut the sleeve away from the dimples, a little force should drop it out. And I use anti sieze on EVERYTHING! I love that little Grey bottle!
              Yours truly,
              Rich
              you kids get off my lawn.....
