No fluid from caliper when bleeding
  • Ijl
    • Apr 2014
    • 53
    So I'll loosen the bleeder and nothing comes out. I've used vacuum & had someone step on the brake....kinda stumped, I've bleed most my cars and never had this happen
  • petrolhead
    • 421
    Replace the bleeding "screw" or check that it isn't blocked by dirt/rust. Push a mig wire or something through it. Brake hose might be "swollen"/damaged or brake line bent etc. Hope this helps.
    Jarno
    • dirtbag30
      • Apr 2013
      • 678
      that ^ something is blocking fluid. check lines for pinched hose. take the bleeder screw completely out to see if fluid comes out, if not its the brake line running to it.
      i have no idea what i am doing with my life
      • Ijl
        • Apr 2014
        • 53
        Took the bleeder off completely ...nothing with a vacuum
        • dnguyen1963
          • Nov 2011
          • 2651
          Then your line is blocked.
          • LJ851
            • 7919
            How did you vacuum without the bleeder fitting?
            Start loosening each fitting in the system starting at the caliper. The component towards the caliper from the first fitting that pushes fluid with pedal pressure is probably the culprit.
            Lorin
            The M30 is God's engine.
            • Ijl
              • Apr 2014
              • 53
              Well looks like I'll be hunting down this bastard this weekend
              • TobyB
                • 5287
                Rubber hoses can constrict shut internally.
                Wow- E30's are getting 2002-esque problems.
                That means I am getting old.
                t
                • flyboyx
                  • 8371
                  most likely there is a problem with the abs pump. i had this happen with one of the e30's i had. no matter what, i couldn't get fluid out of the rears when i bled the brakes. i changed the abs pump and bingo!
                  Gigitty Gigitty!!!!
                  • Steve Corbett
                    • Jul 2012
                    • 449
                    Is this the first time your bleeding the brakes on this car? If so, the calipers themselves may be full of crud. If you loosen the brake line to the caliper and get fluid then the issue is your caliper. I had the same problem. Removed caliper and disasembled and the fluid inside looked like chocolate syrup. If you get no fluid at the caliper hose move to the next joint forward till you get fluid.
                    Steve Corbett
                    1983 528E Scrapped
                    1983 528E Sold
                    1984 745I
                    1984 325E - Sold
                    1989 325I Bronzit-Sold
                    1989 325I Zinno
                    1988 635CSI
