"Floating" feeling in the rear after all new poly bushings
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    You stated the car was an iX. Did you re-use the iX Subframe bushing washer? If so, did you put a spacer or washers under the inner sleeve to account for the difference so the sleeve engages into the slot in the car?
    Originally posted by priapism
    Originally posted by shameson
    • ScHpAnKy
      • 1573
      yup and yup, i found a spacer at the hardware for the subframe bushings that happened to be the properr length and im going to try and do the same with the diff bushing tab mount
      91 318i | 87 535iS
      • Regnar75
        • Sep 2011
        • 483
        any luck on this bro?
        • alloydix
          • 106
          This might get more replies that would be helpful in the "ix" specific section
          • berlow94
            • Jan 2013
            • 1063
            I would put my money on the crappy revshift bushings...
            I miss you ScHpAnKy!!!
            The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
            • Ether-D
              • Sep 2011
              • 2838
              I'm just completely troubled by the tundra in the video. It makes me feel sad.
              Originally posted by Andy.B
              I was born on 3/25…
              • alloydix
                • 106
                I wonder if Toyota would have done better than ford at a slightly different speed. Seems like the suspension was at the natural frequency vibrations at that speed. Higher speed it might have done better than ford.
                • Ether-D
                  • Sep 2011
                  • 2838
                  That makes me feel better. I bet it rides a lot better too…
                  I was born on 3/25…
                  • Northern
                    • 5284
                    Nicest aftermarket bushings I've installed on any of my cars so far. Never heard of anyone else have issues other than shipping either, so I doubt it.
                    • EyExR
                      • Jan 2011
                      • 959
                      Is there rust issues in the body? That could cause the rear to feel noodley..
                      And if you have another set of wheels and tires you could try out, give that a shot.
                      Good luck! I know what iX woes are... SUCKS.
                      My 325iX DIY Threads:
                      Front Wheel Bearing Replacement
                      325iX Rear Subframe Bushings and MUCH more w/pics!
                      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
                      • THEhomelessONE
                        • Oct 2013
                        • 303
                        Sounds like it's something to do with the RTABs. They're supposed to be installed a certain way, I think the thicker ends of the bushings face towards the outsides of each arm. I'm using Condor bushings with no issues.
                        RIP 02/25/15
                        http://www.r3vlimited.com/board/show...16#post4356816
                        • Ether-D
                          • Sep 2011
                          • 2838
                          Lug nuts tight? Sometimes the simplest answer is the right one.
                          I was born on 3/25…
                          • Bullhead
                            • Sep 2014
                            • 532
                            My car was doing the same thing, turns out one of my tires was folding over around corners. It had a broken belt but looked fine straight up.
                            sigpic87 325E The Honey Badger
