Brakes feel weak
  • Th3importedguy
    • Mar 2014
    • 190
    Brakes feel weak
    My brakes don't really feel like they have much stopping power at all. The pads and rotors are almost new. Do I need a brake flush. Can a brake flush fix this problem
    E30 is life :finger:
  • ST1G
    • Oct 2012
    • 6689
    It would be my next step. In fact, I'm having the same issue and it is my next step.
    • Th3importedguy
      • Mar 2014
      • 190
      It's worrying me. I'm going to see if I can get it done in the next few days
      • ///Bimmerfan
        • Dec 2008
        • 730
        Did you check your reservoir for brake fluid? Mine started doing the same thing and it ended up being a leaking master brake cylinder.
        • BobombETA
          • Apr 2008
          • 1575
          New fluid and bleed the air out.
          Presto change-o
          Also, inspect the lines and master cylinder for leaks.
          Instagram
          Current: 99 M3
          Past: 84 325e, 84 528e
          • long tall eta
            • Jul 2010
            • 1536
            not to thread jack, but mine when applying the brakes the peddle is soft and goes way down but when i take my foot off and reapply, i have plenty of peddle. could this also be old fluid causing this?
            • Th3importedguy
              • Mar 2014
              • 190
              I think you've got air in your system
              • Todd Black 88
                • Oct 2007
                • 3449
                I had this issue with a soft peddle first pump, and it turned out to be worn caliper guide bushings. When I would hit the brakes, the caliper would twist slightly and then sit a little farther back from the rotor. After braking the first time(soft) it would need to take up that extra space. Second pump was fine.
                Originally posted by codyep3
                I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                2001 silver/Blk 325 cabby. SOLD
                2002 325xit Sil/blk. SOLD
                2010 F650gs twin
                • 101
                  • Jul 2011
                  • 764
                  I've had three causes that acted similar ...
                  1) Air in the system - like others have said bleed 'em and bleed 'em again to make sure all the air is out.
                  2) Master cylinder seals bypassing. More commonly this causes the pedal to continue to go to the floor slowly when held down, but it can be erratic.
                  3) If the engine speed changes or the idle is erratic, the amount of vacuum going to the booster changes and might make the pedal feel differently at times.
                  101
                  The E30 collection:
                  1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                  1987 325is - Delphin / Black Sport (son #3's)
                  1987 325i Convertible - Triple Black
                  1989 325iX Coupe - Diamondschwarz / Black Comfort
                  1990 325iX Coupe - Sterling Silver / Grey Sport
                  1981 Fiat 124 Spider 2000 - Green / Tan
                  1998 Volvo V70 GLT - White / Tan
                  1998 Volvo S70 T5 manual - White / Taupe
                  2001 Ford Windstar - Silver / Grey (parts hauler)
                  2006 Lexus GX470 - White / Tan (tow rig)
                  • digger
                    • Nov 2005
                    • 5980
                    when you put new pads and discs this effect seems to reduce hence the pedal feel improves noticably. i need to do the same refresh of brakes....
                    • jeffnhiscars
                      • Jun 2011
                      • 6010
                      You could also try deglazing your brake pads.
                      Alice the Time Capsule
