Removing strut housing to LCA ball joint.
  • Panici
    • Dec 2009
    • 2575
    The spring perch on my E30 is rusted through.
    So I'm pulling the strut assembly from my parts car.
    How do I separate the strut assembly from the Lower control arm? I've tried a pickle fork and hammer, and all I've done is tear up the boot. (I don't care about the boot on the parts car, but I don't want to damage the boot on my good car)
    Help!
  • ForcedFirebird
    • Feb 2007
    • 8300
    Pickle forks are for the birds. Get one of these from Harbor Freight. Best $20 you will ever spend. Just make sure you use a wrench and not an impact of any kind, or you will be buying one every time you use it.
    http://www.harborfreight.com/3-4-qua...tor-99849.html
    john@m20guru.com
    Links:
    • enigmaticdream
      • Jan 2010
      • 572
      Or spent $38 and get one that can handle impact guns and multiple uses. I've had mine for about 4-5 years and it has been used well over 20 times.
      http://www.amazon.com/OTC-6297-Ball-...s=tie+rod+tool
      I've had the control arm not come out though and had to resort to a metal hammer against the housing. It eventually separated, but damaged the strut housing. You could probably use a brass hammer to accomplish the same thing.
      1986 911 Supercharged Frakenstrat/Stripped
      1987 325is Delphin/Black (Olga)
      1988 M3 Zinno/Natur (Elsa)
      Manual or STFU
      E30 Chapter of BMW Car Club of America
      E30 Oktoberfest 2017
      • Panici
        • Dec 2009
        • 2575
        That tool did the trick.
        Although the one I found locally cost me $60.
        Next question. The good car has what looks like a wheel speed sensor. The strut I pulled from the parts car does not.
        What is this for? Auto trans? ABS?
        What will happen without a functioning sensor?
        • kronus
          • Apr 2008
          • 13032
          yes, it's ABS
          without it your ABS won't work
          cars beep boop
