Thinking of going boosterless
  • Bimmer_man
    • Jan 2013
    • 1477
    I have a ix and want to relocate or remove the booster all together . I just want to know how much harder is it to stop these cars when you remove the booster. Is it worth it at all or should I just leave it or if there is a thinner booster I could use that would be even better.
    The reason I'm asking is cause I will be having a custom intake manifold made for the car ( because racecar haha). And with the booster there, there is no way in hell an intake is going to fit.
    Please let me know.
    Float like a cadillac sting like a Bimmer!:)
  • Jaxx_
    • Dec 2009
    • 1880
    turn off the car while rolling down hill and pump the brake a few times until it gets hard... you will have your answer.
    • ForcedFirebird
      • Feb 2007
      • 8300
      I have installed Lee's (Massive Brakes) booster delete kit on a customers' car to clear some ITB's. It's not all that bad with the changed pedal ratio. Slightly firmer pedal than stock, but no issues stopping.
      john@m20guru.com
      Links:
      • e30_302
        • Sep 2013
        • 453
        That's not how it works, at all.
        I have the Massive booster delete as well. The trick is getting a master cylinder that gives you the feel you want. I've just installed a Porsche 914 19mm master and have high hopes for it. I'll be testing it this weekend at the track and will report back, but initial driveway testing puts it as the best of the other three master's I've tried.
        • Bimmer_man
          • Jan 2013
          • 1477
          Awesome please let me know that's awesome.
          • Jaxx_
            • Dec 2009
            • 1880
            Is it not? Without vac assist and the factory setup? If you don't change the mechanical advantage either hydraulically or via leverage, won't it be the same force that is required? Or does the brake booster add some sort of significant mechanical resistance that I'm not aware of?
            • haggardfab
              • Sep 2011
              • 283
              why would you go manual and NOT change the mechanical leverage..
              IG: haggardfab
              • Jaxx_
                • Dec 2009
                • 1880
                Don't ask me... Ask the OP.
                • e30_302
                  • Sep 2013
                  • 453
                  So the 914 19mm master is awesome. I never once felt like I was on manual brakes and lacking in braking power. It bolts directly to the Massive booster delete plate and is a dual circuit master.
                  • Bimmer_man
                    • Jan 2013
                    • 1477
                    Oh sweet what did that cost I'll look into it?
                    • e30_302
                      • Sep 2013
                      • 453
                      ebay
                      • Stvstr
                        • Dec 2013
                        • 82
                        Is that with stock brakes otherwise? I thought I remembered a post from you saying you had a big brake kit, and I am wondering if this would work for my stock brakes.
                        • e30_302
                          • Sep 2013
                          • 453
                          UUC's BBK, which they say is very close in piston volume size to stock.
                          • Stvstr
                            • Dec 2013
                            • 82
                            Thanks, that's exactly what I needed to know. I am using a 5/8" Volvo step-bore m/c now with stock brakes but not completely happy with it. It's much better than the e30 m/c was, though.
                            • e30_302
                              • Sep 2013
                              • 453
                              What is it that you're not happy with?
