Which subframe with disc brakes fit rear?
  • Norbert
    • Sep 2013
    • 64
    I have brake drums in the rear on my m20b20 coupe.
    It happened so that i have went into the corner, span out and hit my rear right wheel into the curb which caused my wheel to go inside in the bottom. I tried to inspect, but since i do not have much knowledge on what usually bends and i can hardly see what is bent i suspect the left fork mount on the "bridge" is bent inside towards differential. which caused the fork to more inwards.
    Question is: If i have to change all rear subframe with forks to an option with brake discs which model i should be looking for? And is it worth trying to fix the mounts where left part of fork is connected to it? Or a lot of balancing would be required and it can cause the parts to be more fragile?
    Thanks for any info :)
  • Northern
    I like cupcakes & sh!tboxes
    • 5283
    Anything other than an early 318 or 320i should have rear discs, as far as I know.
    I'm not sure what else is going to be different (ebrake cables?) to swap them.
    Originally posted by priapism
    Originally posted by shameson
    • Norbert
      • Sep 2013
      • 64
      Thanks mate!:ST1G:
      • jeffnhiscars
        • Jun 2011
        • 6011
        You need to change the trailing arms, ebrake cables and of course calipers and rotors. The subframes are all the same.
        Alice the Time Capsule
