Seeking Info on break booster eliminator
  • Sirjustinderek
    • Jun 2014
    • 143
    So I came across the Chase Bay break booster eliminator and was wondering if any of you have experience with it. Couldnt find a thread about the product. Any info/review is appreciated. Thanks guys.
    Chase Bays specializes in High End Fluid Transfer Products focused for Braking, Clutch, Cooling, Fuel Delivery, Oil, and Power Steering.
  • Sirjustinderek
    • Jun 2014
    • 143
    Bump
    • Gertech
      • Jul 2013
      • 180
      Personally, I wouldn't run that master cylinder. With only one fluid port, you'll have no brakes if that line fails for any reason. Having at least two is a better option. I'd suggest Massive's booster delete plate with a modified pedal ratio. You could try different master cylinders to get the pedal feel you desire.
      I'm currently running Massive's plate with the stock master cylinder (21 or 22mm? I forget), a 6.25:1 ratio, and Ireland's 310mm front big brake kit. Car stops great.
      • Sirjustinderek
        • Jun 2014
        • 143
        Thanks for the info Gertech. I was looking at Massives product as well.
        • iansane
          • 1342
          I'm using Massive setup as well. It's great. Really simple install and pedal throw is about perfect. I daily the car all winter.
          84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
          • Sirjustinderek
            • Jun 2014
            • 143
            Are you running the stock MC as well? And upgraded breaks ?
            • iansane
              • 1342
              Stock style parts store reman, with the massive smallest Wilwood kit.
              • Sirjustinderek
                • Jun 2014
                • 143
                Thanks for the input guys. I went ahead and ordered the massive kit
                • Dyagciog
                  • Mar 2014
                  • 164
                  How is the massive booster-less brake effort feel? Compared to stock
                  1990 325IS S54 swap in process
                  2001 Z3M -All Stock 22K car
                  2005 545i -DD
                  1967 Morris Mini Van-Mad Project BMW/Mini Turbo
                  • DMGSI E_TREINTA
                    • Mar 2014
                    • 55
                    Updates?
                    Sent from my iPhone using Tapatalk Pro
                    • Klug
                      • Sep 2011
                      • 804
                      It's rough, honestly- however, the more comfortable you get with it, it grows with you. I'm using the Massive boosterless setup in my s52e30vert and at first I was going to swap in a booster or run hydroboost. Currently, I'm up in the air with all of it and driving the boosterless setup a little more comfortably.
                      Using a 745i e32 MC. Keep in mind, you will need to make two new brake lines from the ABS pump to the MC since it is shorter- so keep that in mind with grabbing a bubble flare too and some line.
                      555Garage - Kingston, PA
                      '13 BMW e70 X5 35d
                      '95 BMW e34 525i
                      '92 BMW e30 325i S52 Vert (Quade the Vert)
                      '92 Range Rover Classic
                      '90 Range Rover Classic
                      '89 BMW e30 325i Coupe (The DIRTY30)
                      '81 VW MK1 Rabbit Caddy Diesel
                      '76 Honda CB550K Cafe/Brat
                      '67 Pontiac LeMans
                      '24 Model T Depot Hack
                      ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5256
                        Originally posted by gertech
                        personally, i wouldn't run that master cylinder. With only one fluid port, you'll have no brakes if that line fails for any reason. Having at least two is a better option. I'd suggest massive's booster delete plate with a modified pedal ratio. You could try different master cylinders to get the pedal feel you desire.
                        I'm currently running massive's plate with the stock master cylinder (21 or 22mm? I forget), a 6.25:1 ratio, and ireland's 310mm front big brake kit. Car stops great.
                        ^+1
                        Originally posted by priapism
                        Originally posted by shameson
