How in the world do you access this nut????? (rear subframe toe adjustment..)
  • vdubspeed
    • Dec 2014
    • 28
    So I installed the camber and toe adjusters and then installed the subframe. Then I installed the controls arms to only realize that getting to the toe nuts was simply impossible. So I lowered the subframe and installed the the control arms. But I had to keep the subframe down a couple inches because gaining access to the nuts is impossible once the subframe is up. Not an issue on my other stock 1989 325i but the adjusters pushed them out a little to far.
    So is the only way to tighten them to lower the subframe???? I can see adjusting toe to be a rather lengthy process once the entire car is back together.
    Thanks,
    Jason
    Built > Bought
    58 Beetle | 79 Rabbit 20vT | 84 GTI TDI |84 GTI 16vT |12 Golf TDI ----89 325i | 99 QCSB Ram Cummins | 02 Burb 4x4 2500
  • vdubspeed
    • Dec 2014
    • 28
    come on guys. I know I'm not the only won't out there!!!
    Built > Bought
    • McGyver
      • 4634
      You sure you didn't put the bolt in backwards?
      • vdubspeed
        • Dec 2014
        • 28
        McGyver...garagistic agrees.
        I got through to the them and they said to flip it. They said the fit is even tighter with aftermarket bushingers there. Glad I went OEM everywhere.
        Atleast I can flip them pretty easy as I haven't full installed everything!
        Built > Bought
        • Todd Black 88
          • Oct 2007
          • 3449
          Ugh
          There is a f'n spider on your jack stand!
          F'k I hate spiders.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • vdubspeed
            • Dec 2014
            • 28
            LMAO! I didn't even see that!!! LOL
            Built > Bought
            • Massimo
              • Jan 2008
              • 3207
              • Cinnabar325is
                • 1064
                I use a ground down 18mm wrench. Just a cheap one I bought at Autozone. I also trimmed down the subframe bushings on the side along that nut to allow better access. It's a very tight fit, but do-able.
                '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  F'k u massimo.
                  Lol
                  2010 F650gs twin
                  • Julien
                    • 7471
                    Start off by not having a ridiculously blown subframe mount.. or just stick the jack stand on the pinch weld.
                    Build Threads:
                    • george graves
                      • 20003
                      I had the same problem - spend hours, and hours on it. My alignment guy had NO issues at getting to the bolt. I think when the suspension is compressed(such as when you're on the alignment rack), you can get at it easier.
                      Originally posted by Matt-B
                      • garagistic
                        • Apr 2011
                        • 1712
                        Put the bolt the other way. With the oem bushings (or "raised" bushings) it shouldn't be too bad. "standard" poly or delrin bushings can be an issue though. Pictured below is the needed modification (these are our delrin subframe bushings but the concept is the same)
                        • TobyB
                          • 5268
                          Yup, the trimming made things a lot easier.
                          I have a cut- and- welded bent wrench for each side- just about the only way I could get
                          a range of adjustment....
                          t
                          • TurboJake
                            • 3780
                            Originally posted by Todd Black 88
                            Ugh
                            F'k I hate spiders.
                            Leave Me Transaction Feedback
                            • AbsorbantNut
                              Non faccio funzionare questa merda
                              • Jun 2010
                              • 2491
                              I ground down an 18mm wrench to get in there for adjustments
                              '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
