Dropping rear subframe
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    I'm in the midst of swapping my rear end to disc brakes and redoing my bushings. Any ways I got all my shit disconnected and my subframe won't budge I've been prying at it for like an hour. I have the trailing arms in a compressed state so they don't bind the subframe drive shaft is out I've heated bushings up etc. Bitch still won't drop
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
  • the imitator
    • May 2013
    • 1006
    I bet you're close man, hit those bushings with some more heat, they are pretty resistant even to direct flame.
    You might be able to take the weight of the car, or a big sludge hammer to knock the subframe studs loose.
    • matthugie
      • Mar 2004
      • 1810
      You can knock the subframe studs up into the cabin, that makes things much easier.
      88 325is - S52 powered
      Originally posted by King Arthur
      We'll not risk another frontal assault, that rabbit's dynamite!
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        I did that and this bitch still won't go
        • IronFreak
          • Dec 2012
          • 3702
          Instagram @rebellionforge
          • 88BlackS-ETA
            • Mar 2013
            • 322
            Sounds like the aluminum collars on the inside of the bushing are stuck in the car. You need to drill them out from the bottom up until the collar isnt attached to the bushing.
            Feedback Thread
            • Red88
              • Nov 2008
              • 1161
              Heat those bushings for a good while, it takes a while for them to even start smoking, I probably take about 15-20 minutes with a propane torch to actually get they the bushing enough to actually break them apart (this depends on how worn they are). The aluminum sleeves will be stuck in the body of the car. Break them off with your favorite sledge, then drill them as shown in the picture and then you'll be able to chisel the piece out of the car by breaking it into 2 pieces
              Have you made a purchase from www.blunttech.com recently?
              sigpic<< wrecked
              • Klug
                • Sep 2011
                • 804
                Get a tap and thread a bolt into the sleeve. Then hammer down with the biggest slege from in the back seat.
                I had the same issue, still did this and it still wouldn't budge. I let the rear subframe weight suspend from the corroded mounts- waited a few days and BOOM- popped out by itself from the weight of everything. Make sure you at least have something to catch the subframe if it does fall in the middle of the night
                555Garage - Kingston, PA
                '13 BMW e70 X5 35d
                '95 BMW e34 525i
                '92 BMW e30 325i S52 Vert (Quade the Vert)
                '92 Range Rover Classic
                '90 Range Rover Classic
                '89 BMW e30 325i Coupe (The DIRTY30)
                '81 VW MK1 Rabbit Caddy Diesel
                '76 Honda CB550K Cafe/Brat
                '67 Pontiac LeMans
                '24 Model T Depot Hack
                ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  I got it just took lots of cussin kicking and screaming
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    I've heard that they like to drive you to the point of blowing your brains out, then they get tired and just fall off the car.
                    On my cabrio the bolts go in to an enclosed body cavity (puns allowed) so you have to pull the subframe with them in place. In my case I pushed the bolts up 3/4 of the way then ran a 5/8 tap in the bushing. Threaded rod and the business end of an Autozone slide hammer did it in 2minutes/sides.....but only after I had loaded the .38
                    Alice the Time Capsule
                    • pshooter
                      • May 2013
                      • 29
                      "Get a tap and thread a bolt into the sleeve. Then hammer down with the biggest slege from in the back seat."
                      That is what worked for me. Couple good whacks and it dropped right out.
                      • Andy.B
                        • Sep 2011
                        • 1650
                        You don't even need a tap. Just user a lag bolt with a tapered tip. It will cut it's own threads in the soft aluminum.
                        • lambo
                          Captain Scene Points
                          • 10953
                          Yepp. That's how I got mine off.
