Front Subframe Crack - options
  • lolcantturn
    • 4588
    This happened. It is the front subframe, you're looking at the engine mount separated from the front subframe because of the crack, this is under the exhaust manifold. The big nut is the control arm nut, hopefully that puts the picture into perspective. Is it worth welding it back in place + reinforcement plates, or rather putting a new subframe in? Thanks.
    Originally posted by TSI
    OEM+
  • efficient
    • Feb 2012
    • 3312
    What is that?
    Can't tell what it is
    • lolcantturn
      • 4588
      Originally posted by efficient
      What is that?
      Updated the original post. The engine mount piece of the subframe is cracked off.
      OEM+
      • Som
        • Jan 2014
        • 126
        Holey rusted metal, Batman!
        (huh?)
        The metal... it's rusty... and has holes in it. Holey.
        Som
        Wouldn't reuse that subframe.
        • rturbo 930
          • Dec 2005
          • 2627
          You would have less down time if you bought another subframe, reinforced it and swapped it in, but I can't see a reason not to reuse that one if that's what you wanna do. Just needs to be cleaned up first. Looks like it's been that way for a while and the unprotected steel has surface rusted. No big deal IMO.
          • lolcantturn
            • 4588
            It looks like I'm just going to replace the subframe. Doesn't seem too troubling once you have an engine brace. Time to soak the bolts in PB blaster now and keep driving the car until I swap subframes in two weeks time.
            One question- Do I have to remove the steering rack from the steering shaft?
            OEM+
            • ravenlord89
              • May 2012
              • 111
              Just get a new and or used none rusted subframe. That isn't worth repairing unless you are already setup for welding, and experienced with metal fabrication.
              1990 BMW 325is 5spd Black
              2005 Subaru Impreza 5spd
              2015 Yamaha FZ-07
              • Som
                • Jan 2014
                • 126
                You don't have to remove the rack from the shaft.
                Depending on what you use the car for, consider reinforcing the engine mounts and the sway bar mounts.
                Som
