Front Crossmember Swap Difficulty?
  • bmwman91
    • Oct 2004
    • 3134
    How difficult is it to remove the front crossmember? I want to weld in engine mount reinforcements, and laying directly under MIG activity is...not the best. It seems like I just need to unbolt the front sway bar, get the control arm balljoint ends loose, unbolt the steering rack and support the engine so that I can unbolt the mounts. Assuming I do all of that, can the crossmember drop/slide out once I remove the 4 big chassis bolts? Any other pro-tips from experienced wrenchers?
    Thanks!
    Transaction Feedback: LINK
    That is pretty much it, though I'd just disconnect the rack from the column, disconnect the tie rods, and drop the subframe and rack as a unit.
    Before re-installing the subframe chase the threads and use anti-seize. If corroded, I'd use new bolts.
    • bmwman91
      • Oct 2004
      • 3134
      Good info, thanks! I take it that trying to slide the crossmember down/back from the steering rack is sort of a pain then?
      • nrubenstein
        • 3148
        I prefer to leave the rack in place and slide the subframe off. It's easier to pull those bolts than disconnect it.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • jeffnhiscars
          • Jun 2011
          • 6011
          Installing a rack around the subframe tabs can be a pain even with a raised engine but I'm thinking that an unbolted subframe should pivot out and around an installed rack rather nicely.
          Alice the Time Capsule
          • bmwman91
            • Oct 2004
            • 3134
            Good info, thanks folks. I'll try sliding the subframe out and leaving everything in place. Assuming I don't get lazy, I will try to take pics and do a little write-up for others.
            • f4tj0n
              • May 2013
              • 411
              I had to do this last weekend to change my oil pan gasket on my 24v and broke all four crossmember bolts.. now im really fucked.
