weld in toe/camber kits orientation
  • jrobie79
    • Mar 2006
    • 2526
    what orientation are you putting the eccentric bolts for the toe (outboard) adjusters? is everyone putting the bolt in from the diff side and the nut on the bushing side or opposite? I feel like bolt should go in from the bushing side to make it easier to adjust and torque the nut down?
    1991 318i ---- 308K - retired
  • matthugie
    • Mar 2004
    • 1810
    I had the bolt going from the outside in towards the diff, worked fine.
    88 325is - S52 powered
    Originally posted by King Arthur
    We'll not risk another frontal assault, that rabbit's dynamite!
    • bimmer630
      • 1230
      I just posted about this same thing
      So you can install them from the outside, facing in so the nuts are on the diff side?
      • reelizmpro
        • 9558
        That's what I did as well since it made the most sense and I didn't have to cut the bushing. You just won't be able to remove the bolt from the car without dropping the subframe but this is no big deal.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • jrobie79
          • Mar 2006
          • 2526
          yeah my subframe is already on the floor, just wanted to double check what people were doing, thanks all
          • iPee
            • Nov 2013
            • 190
            Sorry to bump an old thread but what did you end up doing? I think maybe that's why Garagistic says to cut part of the bushing. It's the only company that I've seen suggest this. I guess it makes sense now, but is there any draw back to cutting it?
