OEM RTA bushings won't go in...Too Soft
  • citizen_insane
    • Jan 2013
    • 216
    I'm trying to install a set of OEM RTABs that I believe are official BMW parts and I can't for the life of me get them in. They are very soft and when I press them in with a vice they just spring back. You can see the rubber bunching up around the lead in chamfer in the picture below. Any ideas how to get these things to go in? I already tried heat and that didn't work. I wish I could fit the whole thing in my freezer, maybe then the rubber would be stiff enough not to deform.
  • jeffnhiscars
    • Jun 2011
    • 6011
    2 thoughts are that your bushing looks to be dry so you are fighting a ton of rubber to steel,friction and that a C clamp will not apply pressure square to the TA.
    this is what I've done a few times and it's 60 seconds once you have it set up.
    Alice the Time Capsule
    • citizen_insane
      • Jan 2013
      • 216
      I'm afraid to use any kind of lubrication because I don't want the bushing to rotate in the housing. The advice I saw online was typically that they should be installed dry.
      • TimeMachinE30
        • Jun 2014
        • 3749
        Just needs to be the right lubricant. Something that will dissipate.. not a jelly substance that would remain. Maybe some soap and water mix is advisable? That combo above I have seen many times before. My noted way to perform the job when my time comes.
        ACS S3 Build / Dinan 5 E34
        • goarmy
          • Nov 2011
          • 622
          Actually I was recommended only water and soap as it will dry quickly and it worked for me.
          • citizen_insane
            • Jan 2013
            • 216
            My fear was trapping water inside the tube and causing corrosion with anything water based. I thought maybe if I could get pure alcohol or something else that wouldn't react with either the metal or the rubber that would work.
            • estoguy
              • May 2013
              • 1087
              Use the soapy water, it'll be fine. You're being paranoid.
              If you ever have to take them out, use the tool shown in the picture above. Just apply some heat using a blowtorch to the housing, then use the homemade tool. Should come out in seconds.
              Estoguy
              • luismpr
                • Jan 2013
                • 17
                ^ what he said. Soapy water is fine. Lubricates enough and dries quickly.
                Sent from my LG-H811 using Tapatalk
                • redlightpete
                  • Mar 2012
                  • 265
                  I use WD-40. It becomes slightly tacky when it dries. Works well for bicycle grips too.
                  • xxlbimmer
                    • Dec 2010
                    • 156
                    hair spray for both the bushings and bike grips. FTW!
                    Chris Leone
                    chrisleonemotorsports.com
                    rollcages and fabrication
                    Remember cross threading is the only thing stronger than loctite!!
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      Actually Cable Pulling Lube is what I use'for all bushings (perfect for CABs). It dries completely, is cheap, water based no no oil or residue and is what the power company uses to pull 2/0 wires through conduit to run power. If it's safe there it should be ok for your bushings :)
                      I would avoid anything with an oil or solvent base.
                      • IRON-E
                        • 16548
                        Weird, mine went in easily, although initially I attempted to put them in already assembled (bushing).
                        The second attempt, was rubber pieces in first and lastly the metal center, well lubricated with the provided solution.
                        @IRON-E30 aka Edwin:D
                        • Coupelx
                          • Oct 2013
                          • 169
                          For those who dont know what this is, it is basically industrial sized KY Jelly.
                          • Todd Black 88
                            • Oct 2007
                            • 3449
                            I use astroglide. If its safe on my girls bits, it's safe on the car
                            Originally posted by codyep3
                            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                            2001 silver/Blk 325 cabby. SOLD
                            2002 325xit Sil/blk. SOLD
                            2010 F650gs twin
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              AKA cable pulling lube :)
