Powercoating the front sub frame. Does anywhere need to be masked off?
  • validius
    • Mar 2015
    • 161
    I have the sub frame out of my parts car. Over the winter i'm going to weld in reinforcements and have it power coated. At first i was thinking i would mask some areas off but looking at Garagetastic's pictures of the sub frames they offer powder coated it doesn't look like they mask off the sleeve on the rear mounting bolt that fits into the chassis or the tapered holes where the ball joint from the control arm goes. These were the areas i was concerned about.
    Does anyone have any experience with this they could share?
    1987 325i Convertible
    2015 Fiesta SFE: 1.0L of 'Woah, is that torque under 2k?'
  • efficient
    • Feb 2012
    • 3312
    I had my spare subframe welded and reinforced then had it powder coated. I didn't cover anything. Fit good and looks nice
    • bimmerboy4444
      • Apr 2013
      • 62
      yes the tapered hole whar the inner ball joint bolts up
      • validius
        • Mar 2015
        • 161
        OK. The locator pin will slide into the unibody OK if its a little thicker?
        • AndrewBird
          The Mad Scientist
          • 11898
          Because it's tapered, it will slide in, but really you should mask it. Just buy a couple rubber stoppers and stuff one in each side of the holes. Then just let the powdercoater know about them so they can pull them before the oven. All the other holes should be fine.
          • jpod999
            • Dec 2015
            • 1401
            You should just be able to tell the powdercoater where you don't want them to paint and they will either tape it off using high temp specialized tape or rubber plugs.
            OBDI M62B44/6 swap
            Transaction feedback
            - jpod999
