Dropped rear subframe - snagged parking brake
  • turbo55
    • Jul 2014
    • 223
    So I just dropped my rear subframe (finally managed to get the seized subframe bushings to release), I thought I had released my parking brake cables, but it looks like they're stuck in the tubes. I undid them from the inside of the car (at the parking brake lever - they don't seem to be under tension there) and got the tube part out of the hub. The cables are still attached to the shoes in the discs, I didn't think these needed to be detached. My expectation was that the metal cable itself would just slide out the tube, but instead it's stuck so I can't move the subframe away from the car at all. What am I doing wrong? The picture below shows the cable and tube at the hub. Thanks!
  • Seawolf
    • Feb 2015
    • 270
    You need to either disconnect the ferrule from the body tube or disconnect the parking brake cable from inside the brake hub. The inner cable end cannot pass through the ferrule.
    The ferrule that connects to the body tube might need a pair of hefty channel locks to shift it, theoretically it will just twist out with a few turns though the reality can be different and they often seize into the tube, PB Blaster is your friend here. Don't use high heat on that body tube, it will just melt the outer plastic cable sleeve and then you'll have a molten mess to clean out of the tube.
    If your ferrules are really stuck in there look for my write up on desperate measures for removing these in the tech FAQs.
    Your alternative is to remove the brake rotors and disconnect the parking brake from the actuator.
    • turbo55
      • Jul 2014
      • 223
      Sounds like I've been working from the wrong side then. Thanks, I'll try getting the ferrules out from the body tubes out tonight.
      • jpod999
        • Dec 2015
        • 1401
        When I pulled my rear subframe I undid the cables from the lever in the car and then pulled them out with the tubes.
        OBDI M62B44/6 swap
        Transaction feedback
        - jpod999
        • jeffnhiscars
          • Jun 2011
          • 6011
          Remove your rotors and detach the cable at the ebrake. Takes 2 minutes and doesn't risk anything. That ferrule has the potential to drive you crazy for nothing
          Alice the Time Capsule
          • turbo55
            • Jul 2014
            • 223
            Gave the ferrules a shot tonight, both came out without issue! I PB blasted then before trying, then used two vise grips to work them back and forth until they came out. Subframe is now free, thanks.
            • Seawolf
              • Feb 2015
              • 270
              Great ! Put plenty of anti-seize on those ferrules before you refit them.
              Even better replace the cables, they aren't expensive.
              • Swendog
                • Jan 2013
                • 375
                After trying removal of the cables by disconnecting at the ebake handle-the ferrules were corroded to the tubes, many days of PB blasting and heat- I ended up destroying one of the cables when the ferrule got stuck in the tube- these cables are only $21 each- replace them when you're doing the subframe and you'll never have to worry about them again- but make sure tubes where ferrule goes in are CLEAN and put a glob of anti-Seize in there for the next owner! Swen
