Symptoms of bad master cylinder
  • E30 Wagen
    • Jul 2005
    • 3434
    Even after doing some research and reading the bently, I just want to double check what the symptoms of a bad master cylinder are. I've replaced the calipers, pads and rotors all around, and I've bled the brakes probably 4 times now with a pressure bleeder. Every time I quickly stomp on the pedal the brakes immediately grab, but every time I slowly and gradually apply the brakes the pedal goes to the floor. If I slowly press the brakes but then stomp on the pedal then the brakes instantly grab. I'm like 95% sure I've bled the brakes correctly, only pumping to about 12psi, along with working the brake pedal, and there's no leaks.
    My Feedback
  • reelizmpro
    • 9558
    Sounds like a bad master cylinder. Pumping builds pressure but holding it down and having it slowly go to the floor means it's losing pressure when it shouldn't. Had one do this and found it was leaking inside the brake booster. It wouldn't put this off as brakes are kinda important.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • jeffnhiscars
      • Jun 2011
      • 6011
      It does sound like a master cylinder. If it's also leaking In to the booster you will need to replace that too since brake fluid will break down the diaphragm in the booster
      Alice the Time Capsule
      • E30 Wagen
        • Jul 2005
        • 3434
        It's possible to replace a master cylinder using a pressure bleeder, right? Or do I have to do that bench bleeding procedure?
        My Feedback
        • jeffnhiscars
          • Jun 2011
          • 6011
          bench bleeding is recommended and should make it easier to get the system fully bled. You can do without it but why would you
          • E30 Wagen
            • Jul 2005
            • 3434
            Figured I ought to update this thread. The issue was that I simply hadn't bled the brakes well enough. I got the help of a friend to manually bleed the system and now the pedal is nice and firm.
            My Feedback
